Go to Post If anybody ever uses a terabyte in the next few years the world would probably come to an end - spadercool [more]
Unread 07-12-2008, 11:19
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: Dual Fisher Price gearbox
Unread 07-12-2008, 11:22
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Re: pic: Dual Fisher Price gearbox
What pitch gears are you using?
If you are going to be making your own custom gearbox anyway, I would not use the AM planetaries and include the reduction in the gearbox (AM products are great but sometimes you can do it yourself and save weight/money).
You may be able to get the gearbox more compact depending on the size (Pitch diameter) gears you use and how you arrange them.
-Vivek
Unread 07-12-2008, 15:30
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
We had a similar transmission design to run ball pickup rollers a few years back, and enlarged the F/P mounting holes so we could get an allen wrench in to remove the F/P mounting bolts that hold the motors to the transmission plate. Makes it easy to remove the motors if they need replacement.
I would recommend the same for the A/M planetary transmissions mounting bolts.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 07-12-2008, 15:34
Hodge1
Additionally, make sure you have ventialation channels machined in the mating surface between the F/P motors and the input plate side of the A/M planetary transmissions. This is the only cooling the F/P motors get.
Sweat the details
Unread 07-12-2008, 15:58
<deleted> posted in wrong thread. oops
Unread 07-12-2008, 18:56
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
What is the output speed?
R.C.
MadTown Robotics Team 1323
Unread 07-12-2008, 19:27
vivek16's Avatar
AKA: vivek
With a 176.16:1 reduction it would be about 89 RPM.
-vivek
Unread 07-12-2008, 19:53
vivek16's Avatar
AKA: vivek
IMO, I think it's too big, PM or IM me if you want some tips on reducing the size.
No offense, but I can't really see there being room for it on a robot right now.
just my two cents, vivek
Unread 07-12-2008, 20:21
R.C.'s Avatar
Agreed, IM Vivek, he has some good ideas up his sleeve .
R.C.
Unread 08-12-2008, 00:40
CraigHickman
With your material costs there, I'd highly recommend looking at the new GEM500 planetaries from Andymark. They'd probably end up cheaper with 4 stages, which would give you a 189:1 ratio (I think).
Out of curiosity, what made you go with that shape?
Unread 09-12-2008, 21:00
The size and shape of the gearbox are specific to a project were working on and fits very nicely vertically in the space its required. The reason for going big was that we have many of the large gears kicking around plus i wanted to keep it to minimal stages. So really the gearbox isn't costing much because its being laser cut along with a much bigger project which is the main focus.
Unread 09-12-2008, 21:02
CraigHickman
Very cool. It's good when teams use what they have. Also props that you successfully designed inside space constraints; that's not always easy to do.
Unread 09-12-2008, 21:22
vivek16's Avatar
AKA: vivek
Ah, if you have contraints, I take back my comments. Good that you're using things you have laying around. You don't always need the sleekest, fanciest solution so long as it works well.
-Vivek
Fisher Price Gearbox nreynolds General Forum 23 22-01-2008 13:18
Fisher Price Gearbox Model? AdamHeard Inventor 1 12-01-2007 05:56
Fisher-Price Gearbox? Aaron Motors 4 17-02-2004 17:41
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
Fisher Price Gearbox Q... Anton Abaya Motors 17 27-01-2002 08:39
