Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Unread 08-12-2008, 08:31
s_forbes's Avatar
anonymous internet person
FRC #0842 (Falcon Robotics)
pic: Cheap 6WD
Unread 08-12-2008, 08:37
Data Nerd
FRC #0079
Re: pic: Cheap 6WD
Looks easy to make, the only concern I would have is can it take a hit? Aside from that, what is the weight and where do I mount bumpers? (assuming they are legal) And how do you tension the chain?
Just a thought but could you save weight by using thin sheet metal as your belly pan?
Unread 08-12-2008, 08:40
goffchris goffchris is offline
FRC #1884
goffchris is an unknown quantity at this point
Re: pic: Cheap 6WD
It is not completely clear from the CAD, but remember that:
1) The middle wheels need to be offset lower, or the robot won't be able to turn easily. We are using a .5 cm offset this year, but I have read about teams using 1/8 inch.
2) Many teams use omni wheels on one or both ends (not the middle) to aid in turning. The omnis compromise pushing power a bit, but make turning much easier.
Unread 08-12-2008, 09:38
xxsumz's Avatar
xxsumz xxsumz is offline
FRC #2625
xxsumz is an unknown quantity at this point
Re: pic: Cheap 6WD
Doesn't look very stable. Maybe its the wheels or the actual frame. What would happen if it were hit on an angle? Tip over?!
ORIGINAL PROFILE ®
► Play ▌▌ Pause ■ Stop
L 0 a D i N G . . . . .
P e R F e C T i 0 N -- T a K e S -- T i M e
Unread 08-12-2008, 10:00
MrForbes MrForbes is offline
Re: pic: Cheap 6WD
I assume the sides and ends are made of some hardwood, such as oak? and the bottom and corner braces are made of a thin plywood? Looks strong! would the weight be about 15 lbs for the wood parts? (just a guess)
Perhaps you could add some vertical pieces of aluminum angle to the corners, to easily mount bumpers to?
Unread 08-12-2008, 10:06
Data Nerd
FRC #0079
Re: pic: Cheap 6WD
What do you mean by hit on an angle? Do you mean if it were hit while going up a ramp?
I would also have to disagree and say that stability would most likely not be an issue unless they put a lot of weight up high but that would be an issue for most chassis. This looks very stable, I am assuming those are 6" wheels which puts almost all of the weight of this chassis below 6". This should be pretty stable unless they pick up like 5 of the old tetras and swing them around 8 feet in the air it should be pretty stable.
Unread 08-12-2008, 12:27
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
Re: pic: Cheap 6WD
This is basically an all wood live-axle version of our 2008 chassis, which worked great (except perhaps the strange chain path I used...). Looks good, but I think it would be preferable to mount the transmissions in the center, so you can use corner plates like on the front on all three corners.
-Gary Forbes
Unread 08-12-2008, 12:30
s_forbes's Avatar
Re: pic: Cheap 6WD
I'm not sure how well it would survive compared to other frames, but with bumpers I don't think it would have any problems. As squirrel pointed out, bumper mounts on the corners are easy to make and work well. For chain tensioning, I like the nylon-circle-with-offset-hole-approach. It has worked well for us in the past and is easy to do.
A sheet metal belly pan would probably save a bit of weight and could be stiffer, but I laid out this frame trying to minimize the number of parts that need to be bought online. All of the wood parts can be easily found at a home improvements store. (although if we built a chassis like this, it would probably have an aluminum base plate. )
It's hard to see in the rendering, but the center wheels (5" banebots wheels) are lowered 1/8".
Actually, having the transmissions in the back has some neat advantages. Since the center wheel is dropped, the rear wheels don't carry as much load. This is probably a lot nicer on the transmissions since the wheel is is about 1.5" from the transmission bearing. Also, with the chain routed this way (one on the inside, one on the outside) the wheels can sit in closer to the frame.
Unread 08-12-2008, 13:15
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: Cheap 6WD
Can you describe the power transmission components in more depth?
Assembling reliable power transmission schemes is the most difficult part of building a FIRST robot's drive train. Without learning more about why you've selected an unorthodox series of chain paths and wheel locations, I would be hesitant in recommending this to any teams with few resources.
--Madison--
...down at the Ozdust!
Unread 08-12-2008, 13:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Cheap 6WD
I don't see your reasoning. The way I'm looking at it, the rear wheels carry more load than if the center wheel were not lowered (up to half the robot's weight or even more, depending on the center of gravity). They just do it intermittently -- which seems likely to cause greater shock loads on the axle when the robot rocks backward.
Unread 08-12-2008, 13:51
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Cheap 6WD
Overall I like it but why wouldn't you just run all the chain on the inside? Also Maybe look into 8wd with the transmission centered and chained to the center pair of wheels. It would increase ramp-climbing ability while keeping the same center of gravity.
Mentor 2415
Unread 08-12-2008, 21:47
s_forbes's Avatar
Re: pic: Cheap 6WD
Well I wouldn't recommend it yet... I would hope that others could offer some criticism and improvements.
Starting at the transmissions, we have two AM toughboxes with the extended output shaft option. The face of the transmission is attached directly to the wooden framerail. On the output shaft, there is a spacer, then a sprocket (12 tooth AM), and then a 5" Banebots wheel. These are held on with a cotter pin and a washer.
The other axle assemblies are similar, with the sprockets and wheels held onto the 1/2" keyed axles by washers and cotter pins. At the moment, I have the flanged bearings sitting right in a 1.125" hole in the hardwood, but this part that worries me the most at the moment. (maybe an aluminum insert?)
That's where I have it at the moment, if you see any problems please point them out.
I was making the comparison between two 6WD frames with a dropped center wheel (I might not have made that clear enough in my first post). With this configuration, the end wheels support a much smaller portion of the total robot weight, especially if it's center of mass sits right over the center wheels.
That is a good point about the shock loads to the transmission, though.
I considered this too, but for this particular version I wanted the transmission face to be flush with the framerail and the wheels to be close to the frame. In its current configuration, the rear wheel is about as close as you can get it to the transmission. (although, it could probably be made to work as you stated as well)
Unread 08-12-2008, 22:21
AKA: Sean
Re: pic: Cheap 6WD
Running all of the chain on the inside would not increase the distance between the wheel and the bearings at all. It would simply require a longer axle on the inside of the frame.
Mentor 2415
Unread 08-12-2008, 23:25
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: pic: Cheap 6WD
How fast do you estimate it will go?
Direct drive off of ToughBoxes seems a little fast.
Could the wheels be any smaller?
I like the chain on the outside.
It makes it easy to get to the chain and it simplifies the ToughBox mounting since you don't have to make spacers between the frame and the gearbox.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 08-12-2008, 23:45
s_forbes's Avatar
Re: pic: Cheap 6WD
There isn't a bearing in the frame at the rear wheel, so the wheel is supported by the transmission bearings. A bearing could be put there though, and then the chain run on the inside. I've always thought it was a good idea not to run three bearings on the same shaft though.
I would estimate about 8 ft/sec. A 5" wheel on the toughbox gives about 9 ft/sec at the free speed of the CIMs, but there is going to be some frictional loss.
pic: re-modified 6wd spc295 Extra Discussion 15 19-11-2008 15:14
