Go to Post 217 would never collaborate with 1114 because they are crazy and they talk funny. - Paul Copioli [more]
Unread 08-12-2008, 22:45
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: New Chassis Concept
Originally Posted by chris31 View Post
Yeah. I have a few ideas starting to be drawn. Just nothing is final in CAD yet.
Its McMaster 1630T14. So you recommending something thinner with less pocketing. Thats doable. Im still playing around with best ideas for removing weight and keeping strength.
Chris I like your stuff and if you need any help with CAD, please email me. Try using 1x2 aluminum. We have using a 1/16 wall and it is fairly light. You can even pocket some out on the sides but none on the top. We created a frame that had a ton of cnc work and played battle bots with it to see if it would crumble. Plus stress testing told us it would be fine. Make sure you have a safety factor of 10 ((Just to be extremely Safe))
R.C.
MadTown Robotics Team 1323
Unread 09-12-2008, 17:56
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Just the 6 pieces of C channel totally 14.13 pounds whereas the same length of 1x2 with 1/6in walls is about 7.7 so I see what you are saying about weight.
Cory, whats so hard about machining C channel? Im not a machinist but the machinist didnt say anything when I drew a quick concept for him.
Unread 09-12-2008, 18:00
Both the cutter and the vice exert lots of force on the part. Square/rectangular tubing has walls that resist forces rather well in all directions square to a face. C channell is "missing" a side which often can make it hard to clamp in certain orientations (for example, vertically you'd only be holding the ends of the bottom leg), and hard to actually cut in certain orientations (the legs will deflect from the cutter probably, leaving poor finishes). There are ways to get around that of course, but ideally you'd make machining as easy as possible.
The 2x1 will also result in a much more rigid frame, it doesn't twist along it's own long axis as easily as the C channel will.
Unread 09-12-2008, 20:12
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
Our team's robot for the last few years has had the motors directly drive the middle wheel. This could make turning easier if you drove those wheels instead
Unread 09-12-2008, 20:15
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
not to be negative but,
could just save yourself the trouble and use the kitbot chasssis....................
would loose the cool factor though.........
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 09-12-2008, 22:26
Team 2021 Captain
AKA: Chris Davidson
Adam, that makes sense. Thanks for the input.
All six wheels are powered in this design.
Well, that kind of defeats the purpose of having the chassis design the way you want it and work to your needs. It also wouldnt be much of a learning experience to just bolt some frame material together.
Unread 10-12-2008, 16:50
gorrilla's Avatar
AKA: adam spears
yeah but it saves money and valuable time.
any other teams weld theirs?
Adam Spears
Unread 10-12-2008, 17:30
Team 2021 Captain
AKA: Chris Davidson
Sorry, Im not really looking for recommendations on why I should use the kitbot chassis.
Unread 10-12-2008, 18:04
gorrilla's Avatar
AKA: adam spears
well i was just putting it out there...............
Adam Spears
Unread 10-12-2008, 18:07
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Now is the time to be designing new drivetrains, and telling a team to just use the kit frame right now is not really a good way to encourage new development and growth. Yes in some instances and for some teams it would be better to just use the kit frame; however, a lot of teams can pull off a better custom chassis that fits there needs perfectly. Also we don't even know if we will be given the same kit frame this season.
Mentor 2415
Unread 10-12-2008, 18:18
gorrilla's Avatar
AKA: adam spears
i know this, and it was just a suggestion...
i also know that if my team had access to all the tools and materials needed, we probobly would...
i am all for encouragement and new growth, just commenting.......
Adam Spears
Unread 10-12-2008, 18:25
AKA: Sean
You should look into having standoffs between the plates. That would add a ton of strength.
Mentor 2415
Unread 10-12-2008, 19:07
Team 2021 Captain
AKA: Chris Davidson
Thanks for the recommendation. Ill be working them into the design after I finish finals (tomorrow).
Unread 10-12-2008, 19:19
AKA: Sean
If you have the resources, I would recomend making your own standoffs out of delrin. This way they could be a larger diameter and distribute the load better and still be lighter than aluminum standoffs.
Mentor 2415
Unread 10-12-2008, 19:26
If the delrin standoffs are threaded, they will be much lighter than aluminum overall, but the threads won't hold up real well.
If the they are thru holes, they bolt increases the weight a lot as it is rather long. I'd Imagine an aluminum standoff with tapped ends is lighter than a delrin standoff with a thru bolt of comparable strength,
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
Interesting new robotic automation concept Grant Cox General Forum 2 15-05-2007 11:22
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
A New Concept for the Tournament Structure in 2004 Andrew Rules/Strategy 38 07-07-2003 12:30
