#16
Re: pic: New Chassis Concept
Just the 6 pieces of C channel totally 14.13 pounds whereas the same length of 1x2 with 1/6in walls is about 7.7 so I see what you are saying about weight.
Cory, whats so hard about machining C channel? Im not a machinist but the machinist didnt say anything when I drew a quick concept for him. |
#18
The 2x1 will also result in a much more rigid frame, it doesn't twist along it's own long axis as easily as the C channel will. |
#19
Our team's robot for the last few years has had the motors directly drive the middle wheel. This could make turning easier if you drove those wheels instead
#20
not to be negative but,
could just save yourself the trouble and use the kitbot chasssis.................... would loose the cool factor though......... |
#21
Adam, that makes sense. Thanks for the input.
Well, that kind of defeats the purpose of having the chassis design the way you want it and work to your needs. It also wouldnt be much of a learning experience to just bolt some frame material together. Last edited by chris31 : 09-12-2008 at 23:12. |
#22
yeah but it saves money and valuable time. any other teams weld theirs? |
#23
Sorry, Im not really looking for recommendations on why I should use the kitbot chassis.
#24
well i was just putting it out there............... |
#25
Now is the time to be designing new drivetrains, and telling a team to just use the kit frame right now is not really a good way to encourage new development and growth. Yes in some instances and for some teams it would be better to just use the kit frame; however, a lot of teams can pull off a better custom chassis that fits there needs perfectly. Also we don't even know if we will be given the same kit frame this season.
#26
i know this, and it was just a suggestion... i also know that if my team had access to all the tools and materials needed, we probobly would... i am all for encouragement and new growth, just commenting....... |
#27
You should look into having standoffs between the plates. That would add a ton of strength.
#28
Thanks for the recommendation. Ill be working them into the design after I finish finals (tomorrow).
#29
If you have the resources, I would recomend making your own standoffs out of delrin. This way they could be a larger diameter and distribute the load better and still be lighter than aluminum standoffs.
#30
If the they are thru holes, they bolt increases the weight a lot as it is rather long. I'd Imagine an aluminum standoff with tapped ends is lighter than a delrin standoff with a thru bolt of comparable strength, |
| pic: Concept Frame | armoredvehicle | Extra Discussion | 6 | 16-12-2007 20:55 |
| Interesting new robotic automation concept | Grant Cox | General Forum | 2 | 15-05-2007 11:22 |
| pic: Claw^2 Concept | CD47-Bot | Extra Discussion | 8 | 06-02-2004 14:08 |
| pic: Crab Concept 6 | CD47-Bot | Extra Discussion | 13 | 14-11-2003 22:03 |
| A New Concept for the Tournament Structure in 2004 | Andrew | Rules/Strategy | 38 | 07-07-2003 12:30 |
