Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
  #31   Spotlight this post!
Unread 10-12-2008, 20:38
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: New Chassis Concept
If the delrin standoffs are threaded, they will be much lighter than aluminum overall, but the threads won't hold up real well.
If the they are thru holes, they bolt increases the weight a lot as it is rather long. I'd Imagine an aluminum standoff with tapped ends is lighter than a delrin standoff with a thru bolt of comparable strength,
That is a very good point. I have actually not thought about that before. One nice thing about a thru-bolt with a delrin spacer is that you could buy delrin round stock and make the spacers yourself saving a ton of money. We spent $150 just on standoffs for our drivetrain last year which used COTS threaded standoffs.
Mentor 2415
  #32   Spotlight this post!
Unread 10-12-2008, 20:52
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
We should be able to buy raw stock and tap the standoffs ourselves, so that should be be much of a problem.
  #33   Spotlight this post!
Unread 11-12-2008, 09:02
rally_racin'_94's Avatar
rally_racin'_94 rally_racin'_94 is offline
Rookie
AKA: Cody
FRC #2062 (C.O.R.E)
rally_racin'_94 is an unknown quantity at this point
6 wheel drive???
or less??
"Confidence is the key to great acts of courage"
"pain is weakness leaving the body"
  #34   Spotlight this post!
Unread 11-12-2008, 09:04
Rookie
AKA: Cody
FRC #2062 (C.O.R.E)
how would you get it to turn with 6 wheel drive because all the wheels have a sprocket
  #35   Spotlight this post!
Unread 11-12-2008, 09:58
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
if all the wheels are powered it shouldent have a problem turning............
its tank drive presumably not car steering.........
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #36   Spotlight this post!
Unread 11-12-2008, 11:43
Team 2021 Captain
AKA: Chris Davidson
Yes, its tank drive.
Tank drive. Its been done over and over again successfully.
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
Interesting new robotic automation concept Grant Cox General Forum 2 15-05-2007 11:22
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
A New Concept for the Tournament Structure in 2004 Andrew Rules/Strategy 38 07-07-2003 12:30
