Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Go Back   Chief Delphi > Technical > Control System > FRC Control System
Unread 16-12-2008, 11:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Top Ten Things NOT to do with the 2009 FRC Control System
The heading seems a bit alarmist. I usually think of Don't lists as things that will break something. So 5-8 and 10 seem a little overblown. Also:
2. Misleading. You can update in whatever order you like. Should be, "Don't run different software versions (or update levels) on your PC, cRIO, or Driver's Station"
3. Somewhat misleading. You'd probably be fine mounting the cRIO or camera on a small piece of metal, as long as the metal itself is isolated from the rest of your robot's frame.
5. Incorrect. You can use the inputs just fine without pullup or pulldown resistors by actively switching the signal wire from +5V to GND. Or by actively driving the inputs with an external circuit. The only problem is simply connecting signal to ground or 5V and expecting the input to change state when you break that connection.
6. Silly, as the robot won't operate without a dongle. Perhaps, "Don't lose your Enable Dongle" would be more meaningful.
7. Incorrect. The robot wireless, drivers station, and most modern laptop and computer interfaces have auto-sensing technology, and would operate fine with a cross-over cable. So the only cable that absolutely has to be correct is the crossover between port 2 and the camera.
Before being so quick to criticize, one might consider the identity of the original poster, and why he may be providing the information that has been posted. Vince knows what he is talking about, and there is logic to each of his statements.
Wisdom is knowing the difference between "the way to do things" and "the right way to do things." Just because an action may be physically possible does not mean that it is smart to do. Vince is wise. Listen to him.
-dave
Unread 16-12-2008, 13:39
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
My first impression when reading Kevin's post was:
"Dude! That's Vince you're talking about! I think you should probably just shut up and listen!"
Dave said it much better than I would have.
-John
Unread 16-12-2008, 16:55
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Maybe I'm the only one who hasn't heard of him, but who is Vince and why shouldn't we question him?
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 16-12-2008, 17:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Vince Wilczynski
--Madison--
...down at the Ozdust!
Northern California Area - 2009 FRC Control System Seminar Laura Rhodes FRC Control System 2 16-11-2008 21:04
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
**FIRST EMAIL**/ FRC 2009 Control System Early Release Update dlavery FIRST E-Mail Blast Archive 12 15-10-2008 19:30
2009 FRC Control System Forums Open now BornaE FRC Control System 7 01-10-2008 19:02
