Re: pic: Another Cheap Wood Frame Idea
The cantilevered axle design has some advantages and some disadvantages. One advantage is that it's pretty easy to work on it, another is that the holes don't have to be aligned, another is that it saves the weight of the outer piece of wood, and since there's a bumper there anyways that piece of wood is kind of redundant. On the downside, it takes a bigger axle with a strong attachment to equal the strength of a non-cantilevered design. We used a chassis layout almost identical to this one last season, with pultruded fiberglass C channel for the side and end rails, and sheet aluminum for the bellypan and gussets. Axles were 1/2" threaded rod with big flange nuts holding them to the fiberglass. It worked well, and we felt it was easier to work on the drivetrain with this design, than with the double-supported dead axles we used the previous two years. Also, building the chassis took less time. We are beginning to think that getting a chassis built and running quickly is a good thing, so the team can concentrate on the game-playing parts of the robot. That's one reason we are taking a lot of time playing with new chassis ideas now, hopefully we'll have enough design ideas ready to go that we can pick one and built it by the end of the first week. Last edited by MrForbes : 12-21-2008 at 07:45 PM. |
of the two, which do you think is the easiest to build and most durable? and were do you guys get pultruded fiberglass channel Last edited by gorrilla : 12-21-2008 at 07:55 PM. |
I think we got the fiberglass from Creative Pultrusions, we bought a bunch our rookie year. I think that cantilevered axles are easier to build, but do need to be made stronger since they are only supported at one end.
on a 6wd base, why not just direct-drive two of the wheels on each side(using say, a bb transmission), then run a chain the the last one? that way you would only need to really make one dead canilevered axle Last edited by gorrilla : 12-21-2008 at 09:27 PM. |
I do think carbon fiber tubes are The Bomb for robot arms, but haven't had a chance to try it due to the famously conservative students on the FRC team with which I used to work. We need some pictures of your longboard(s). Here's a link to pictures one of my boats: http://www.jemwatercraft.com/images/...ahPictures.htm, made from 4mm okoume and 6-ounce fiberglass. And other stuff! |
This discussion is making it look pretty sensible to just cut up some plywood on the table saw, and glue it together!
![]() The carbon fiber tube idea is nifty, but kind of pricey for those on a limited budget. http://www.carbonfibertubeshop.com/large%20tubing.html |
Interesting stuff, we'll have to look into it.
Back to the Quick Affordable Wood Chassis....Gary finally came home and made a sample cantilevered dead axle. Yeah, it's pretty simple, a dollar and a half for a bolt, hacksaw the head off, drill a 1/8" hole for a cotter pin to retain the wheel. ![]() Hopefully he'll get some Inventor work done and show us what the chassis with the axles and Toughboxes could look like. |
#10
Carbon Fiber?
http://www.inlinewarehouse.com/descpage-NB95SHI.html |
#11
did you just glue the bottom panel on? or is stapled also?
#12
The bottom panel is glued and stapled.
| Another electical setup idea from my team fo 08... | cdennisxlx2 | Electrical | 13 | 10-11-2007 01:47 PM |
| Another idea for future competitions | archiver | 2001 | 13 | 06-24-2002 03:33 AM |
| Another Idea of Expanding the Nationals | archiver | 2001 | 2 | 06-24-2002 03:28 AM |
| Another idea looking for comments | archiver | 1999 | 16 | 06-23-2002 10:01 PM |
