Re: pic: Another Cheap Wood Frame Idea
I think we got the fiberglass from Creative Pultrusions, we bought a bunch our rookie year. I think that cantilevered axles are easier to build, but do need to be made stronger since they are only supported at one end.
on a 6wd base, why not just direct-drive two of the wheels on each side(using say, a bb transmission), then run a chain the the last one? that way you would only need to really make one dead canilevered axle Last edited by gorrilla : 12-21-2008 at 09:27 PM. |
I do think carbon fiber tubes are The Bomb for robot arms, but haven't had a chance to try it due to the famously conservative students on the FRC team with which I used to work. We need some pictures of your longboard(s). Here's a link to pictures one of my boats: http://www.jemwatercraft.com/images/...ahPictures.htm, made from 4mm okoume and 6-ounce fiberglass. And other stuff! |
This discussion is making it look pretty sensible to just cut up some plywood on the table saw, and glue it together!
![]() The carbon fiber tube idea is nifty, but kind of pricey for those on a limited budget. http://www.carbonfibertubeshop.com/large%20tubing.html |
Interesting stuff, we'll have to look into it.
Back to the Quick Affordable Wood Chassis....Gary finally came home and made a sample cantilevered dead axle. Yeah, it's pretty simple, a dollar and a half for a bolt, hacksaw the head off, drill a 1/8" hole for a cotter pin to retain the wheel. ![]() Hopefully he'll get some Inventor work done and show us what the chassis with the axles and Toughboxes could look like. |
Carbon Fiber?
http://www.inlinewarehouse.com/descpage-NB95SHI.html |
did you just glue the bottom panel on? or is stapled also?
#10
The bottom panel is glued and stapled.
#11
I substituted 3/4inch plywood for a 2x69(because 3/4inch ply was 40 bucks) for the sides and ends, I have the frame built except for the bottom panel is not attached and the corner bracketes are not on yet, Im waiting fo the liquid nails to harden completely...
It does feel really solid and stiff( I cant make it flex at all) so once I glue and screw the bottom and corners brackets on it should be solid as a rock..... pics are soon to come ![]() Last edited by gorrilla : 12-23-2008 at 08:08 PM. |
| Another electical setup idea from my team fo 08... | cdennisxlx2 | Electrical | 13 | 10-11-2007 01:47 PM |
| Another idea for future competitions | archiver | 2001 | 13 | 06-24-2002 03:33 AM |
| Another Idea of Expanding the Nationals | archiver | 2001 | 2 | 06-24-2002 03:28 AM |
| Another idea looking for comments | archiver | 1999 | 16 | 06-23-2002 10:01 PM |
