Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
Unread 26-12-2008, 22:41
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: Madtown Marauders Wheel
Unread 26-12-2008, 22:42
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Madtown Marauders Wheel
That looks awesome. Now what is the weight and its dimensions? Also how are you driving it?
Mentor 2415
Unread 26-12-2008, 22:45
R.C.'s Avatar
Sorry, took a bit to write the description.
R.C.
MadTown Robotics Team 1323
Unread 26-12-2008, 23:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
To be blunt, there is no way those spokes are not going to break.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-12-2008, 23:06
I'm wondering the exact same thing. Unless the picture is at an angle and we don't see the full spoke?
RC did tell me that Sunrise Medical told them the wheels were tested and tested again. They were concluded to be stronger than Al.
RC, did they say what plastic it is? Because although I would trust their engineers, I am a bit skeptical. Don't know if they'd be fit for an environment such as FRC fields and matches.
Unread 26-12-2008, 23:11
R.C.'s Avatar
Yeah, they did not say what plastic it is and they did say it is stronger than AL. These guys build quality stuff and their whole company is about quality. Cory, we have tried breaking these spokes and this wheel is pretty solid. We will test these wheels out before season starts. What i need right now are ideas about mounting the sprocket. Remember this wheel has to last 8 years on a wheel chair that holds a 120+ pound person.
R.C.
Unread 26-12-2008, 23:15
FRC #0234 (Cyber Blue)
Rookie Year: 1942
You might be able to use AndyMark hubs and attach sprockets to them.
You can use the axle to align the hubs and wheel and keep things centered, and then possibly bolt through front to back (i think the hubs have six holes) and sandwich the wheel between two hubs or a hub and a plate.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 26-12-2008, 23:18
AKA: Sean
You could maybe try pressing in a keyed hub of some kind possibly with jb-weld or some other strong epoxy as well. Unfortunately those wheels look really difficult to adapt to.
Mentor 2415
Unread 26-12-2008, 23:44
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
how about gluing a plate to the outer wheel rim and bolting the sprocket to that?
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 26-12-2008, 23:57
R.C.'s Avatar
Here's a link to a better view:
http://www.team1323.com/Pages/wheel1.html
R.C.
Unread 26-12-2008, 23:59
artdutra04's Avatar
VEX Robotics Engineer
It's not hard to use a wheel like this, but get ready for some machining. The easiest way I can think of is to make two plates that sandwich the wheel with half of the spoke profile milled into them each, so they fit snuggly into the wheel. Then use bolts to clamp the two plates together, trapping the wheel and using milled grooves and the spoke pattern to transfer the torque.
Then to power the wheel, either drill a hole pattern into these two sandwiching plates for a dead axle drive train, or make one of the pieces out of aluminum (the other could be polycarbonate to name an example) and broach it for a live axle.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-12-2008, 00:01
run the trap!!!
Team Role: Human Player
[fist shaking/] argg... Dutra beats me to it... [/fist shaking]
Terrific their engineers might be, but I don't think my grandmother or her walker would last long in a FIRST match Although I dare say she’d try and make me proud
BTW, your link is broken RC.
-Philip J. Fry
Unread 27-12-2008, 00:12
R.C.'s Avatar
I fixed the link, it was being stupid!
R.C.
Unread 27-12-2008, 00:27
[fist shaking/]Although I dare say she’d try and make me proud
Lol.
We might hold these off for non competition robots too btw. Doesn't have to be strictly for FRC either.
Unread 27-12-2008, 03:07
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
If you're gonna go to all that trouble, you might just want to machine a whole custom wheel from aluminum.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
pic: Madtown Marauders DT of DOOM-2 R.C. Extra Discussion 19 10-01-2010 19:16
pic: Madtown Marauders DT of DOOM-1 R.C. Extra Discussion 2 27-12-2008 16:50
pic: Madtown Marauders DT of DOOM-3 R.C. Extra Discussion 4 16-12-2008 22:57
pic: Madtown Robotics 07-08 Frame R.C. Extra Discussion 4 09-07-2008 17:27
pic: Madtown 1323 Proto 2 R.C. Extra Discussion 12 20-06-2008 20:27
