#46
Re: pic: Cheap 6WD
We visited a friend who's into RC planes this morning, he suggested smearing some baking soda on the wood, then adding some thin CA, and beware of fumes. I guess we'll have to get some CA adhesive and make it part of our experiments.
#47
Re: pic: Cheap 6WD
OK, I guess I have to confess, I learned the CA trick while building RC planes. The baking soda works much like "kicker" for the CA, accelerating the cure. This may or may not be a good thing in this case. It may cause the adhesive to cure too fast, not allowing it to wick as far into the wood. I think you are right, some experimentation may be in order.
Rick, I like epoxy for this also, but the 1 to 1 mixes found at the hardware store are too thick in my opinion. A laminating epoxy like West or Pro-set are better choices. This also takes a lot longer to cure and the protective gloves warning still stands. I like this thread, lots of good techniques for extending the utility of an inexpensive, easy to use material. |
#48
Re: pic: Cheap 6WD
could use this perhaps http://www.3m.com/US/auto_marine_aer...ml?itemNbr=208 ive used it before on my hobie cat, its pretty tough sutff.... although ive found it does crack when there is high force dircted at it(such as if it was hit with a chisel after it had cured)but it does work good for filling things Last edited by gorrilla : 23-12-2008 at 22:13. |
#49
Re: pic: Cheap 6WD
My team is making a similar prototype with six wheels, except we have the middle wheels powered instead of the rear. I think that this this rear drive is a better design but some people on my team don't think so. Can anyone give me any reasons why one would be better than the other (possibly someone to quote) so that I can convince my team?
thanks |
#50
Re: pic: Cheap 6WD
I wonder if section 4.6 of the manual also applies just to the crate or everything being shipped?
http://www.usfirst.org/community/frc...nt.aspx?id=452 |
#51
Re: pic: Cheap 6WD
-To make mounting the transmission easy, it would be face mounted to the wood (so no chain can run from the transmission on the inside of the frame) -To minimize bending load on the transmission shaft, the directly-driven wheel needs to be as close in to the frame as possible. This means only one chain can be connected to the driven wheel, which means the transmission needs to be on an end. This obviously doesn't apply to all designs, it's just the path I took for this particular one. |
| pic: re-modified 6wd | spc295 | Extra Discussion | 15 | 19-11-2008 15:14 |
| pic: 6wd chassis | spc295 | Extra Discussion | 21 | 10-11-2008 09:00 |
| pic: 6WD Module | Madison | Technical Discussion | 20 | 12-01-2007 10:09 |
