Go to Post It is probable that you will find mroe than a few spotlight worthy phrases or sentences in the following. ;) - sanddrag [more]
Unread 01-01-2009, 01:12
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis
Always listen to your gut instinct. ;-)
Something inside of me was screaming that 41.5 pounds was way too high, that something was wrong.
And after looking through all the models again, the error was found; I never manually entered in the weight of the downloaded Colson wheel model, so it used whatever the default density was. This estimated weight ended up being about 1.58 pounds per wheel!
Properly entering in the weight droped the total weight down to 39.30 pounds.
And since I was already on this train of thought, I went back to the specs on the Colson wheels and found that by dropping from 2" width wheels* to the 1.5" width Performa wheels, an additional 1.932 pounds could be lost, bringing the total weight to 37.37 pounds. On top of this, a slight modification to the aluminum inserts pressed into the Colson wheels loses another 0.3 pounds, which brings the weight down to 37.07 lbs. (Which is right in the 36-38 pound range I was expecting).
* The original reason for using the 2" Colson wheels was because we already had a set on our 2008 competition and practice robots; of these the practice robot set would make the migration onto our 2009 practice robot.
Art Dutra IV
世上无难事,只怕有心人.
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 14:20
pic: GUS Team 228's 'Drive-by' Autonomous artdutra04 Extra Discussion 4 23-05-2007 20:11
Introducing: GUS Team 228's 2007 Website! artdutra04 Website Design/Showcase 18 20-03-2007 19:46
