Go to Post Being consistently enthusiastic with a consistent message is not easy to do without sounding like a cult. We could use a reasonably large collection of things to say that restate the mission and vision of FIRST but don't appear to be stock phrases. - Alan Anderson [more]
Unread 03-01-2009, 01:44
Collin Buchan's Avatar
Collin Buchan Collin Buchan is offline
FRC #2583 (Westwood Robotics)
Collin Buchan is an unknown quantity at this point
Re: pic: 6wd prototype chassis
Originally Posted by NickE View Post
5/8" sounds like overkill for me for dead axles. I would probably recommend 3/8" for that situation.
This is probably true. The ID of the bearings on the AM wheels are 5/8", so if we wanted to make it smaller we'd have to use a hub.
Just looking at that design, 7 sprockets per side of the drivetrain, with one direct driven wheel, looks way overkill. I'm not quite sure on the function of the extra four, but it appears to be some sort of elaborate chain run in order to use one chain per side.
As it is, on the center wheel assembly there's a copper bushing (to decrease the 5/8" ID to 1/2"), the wheel, the sprocket, and a keyed hub to drive the whole thing. With this current design, I wasn't able to fit in two sprockets on the wheel assembly and have it all still fit on the extended output shaft of the gearbox. I suppose I could look around for other wheels that aren't as wide and it might kill two birds with one stone - the IFI ones might do the trick.
1/4" plate sounds like overkill, but in this situation, it could be necessary to use [relatively] thick sheet metal to maintain rigidity in the chassis. If you have the capability, you might consider adding flanges
I'm not familiar with adding flanges, and I don't know if we have the capability of machining it. If we used 1/8" or 3/16" aluminum, would it be necessary to add flanges to ensure rigidity in the frame? If so, what size would they need to be?
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 14:20
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
