Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 04-01-2009, 13:29
rachakate's Avatar
rachakate rachakate is offline
Life's Good
AKA: Kate Leipold
FRC #0340 (Greater Rochester Robotics)
Rookie Year: 1997
rachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud of
Send a message via AIM to rachakate Send a message via Yahoo to rachakate
Re: pic: Orbitz ball modeled in ProE
The straps do not have a "diameter" They are pentagons with big rounds on the corners. Using a round strap would have interference between straps. When you use the pentagon, assemble the straps so that the point of one crosses the flat of another one.
Using ProE Erik Pro ENGINEER / Creo 10 26-02-2009 14:06
pic: Marvin The Martian modeled in SolidWorks Elgin Clock SolidWorks 4 06-04-2006 09:02
ProE Assembly Editing daramana Inventor 5 31-01-2005 13:21
Modeled Kit Parts archiver 2001 1 23-06-2002 23:46
