Go to Post Social life? Ha! Robotics is my social life. :D - Éowyn [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 05-01-2009, 13:34
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: Homemade Orbit Ball! (White Paper Coming Soon)
Originally Posted by Woody1458 View Post
Is the spring constant approximately equal between the real and reproduced? A good test would be resting a heavy book on one, measuring then depression then doing the same to the other.
Originally Posted by Vikesrock View Post
Unfortunately this is also a good way to break them.
OK maybe a medium weight book Start at Dr Suess, and move up to JK Rowling.
I just did this test by stacking six encyclopedia volumes each upon both the real Orbit ball and the reproduction side by side, and they compressed nearly the exact same amount (they were within 3/8" of each other, which I'd guess is within the tolerance of the balls anyway).
Originally Posted by EricVicenti View Post
I also reccomend dropping the real one and fake one at the same time while videotaping. On the tape you can count the bounces and see the height, comparing the consistancy.
I also did this test by simultaneously dropping both balls next to each other, as well as a second test of throwing the balls at the ground at the same time with same velocity. In both tests, they bounced to the exact same height. Between these results, and the compression results from above, I'd consider these a nearly perfect reproduction of the Orbit Ball. (Except the polycarbonate rings don't break easily!)
What are the actual balls made of?
I still don't know, but .062" polycarbonate provides a very good approximation for cheaper than many other plastics (using McMaster prices).
Also, did you happen to measure the internal plastic on a stock ball?
I don't want to take apart one of our five actual Orbit balls, as they are all still unbroken. However using calipers I estimate that the interior ring is 1.00" wide with an I or C channel shape. The edges are about .093" thick, and I cannot really tell the thickness of the inside between the two, but I'm estimating it's about .050"
Originally Posted by Mr_I View Post
Perhaps this might plant a seed of thought: We're wondering if we can find a plastic jug (gallon or 1.5 gallon, maybe from a bleach bottle?) that is about the right size, and then slice it on a bandsaw to 1" strips. Finding such a container might make it easier to make, since A) you could use 2 or three rings whole, B) the plastic is already round, and C) the jugs might be readily available and essentially free.
Milk jugs or similar plastic containers are only a few thousandths thick, and lose nearly all of their strength as soon as the container is breached (with holes, cuts, etc). I don't think it would be feasible to make full-scale reproduction with same characteristics, but they may have potential for 1/3-scale Vex prototyping.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-01-2009, 13:42
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
We are eagerly looking forward to this whitepaper since it seems we have a much more time consuming repeat of the tetras year if we want enough to host our pre-ship scrimmage
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
I guess the next challenge is to make them break realistically....
Unread 05-01-2009, 13:44
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
Thanks for this Art, and thank your dad too!
I can't wait to see your YouTube help video and your white paper.
This is FIRST inginuity at its finest!
Way to think outside the box!
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 05-01-2009, 13:54
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
We might very well be doing this... I've never seen a Wal-Mart in our area. I searched, and the closest one (according to the store locator) is almost 10 miles away.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 05-01-2009, 14:10
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
As a quick word to the wise, it may be worth checking with the manufacturer to ensure there aren't any patent/copyright issues with reproducing the Orbit balls. I'd imagine most toy companies would patent any sort of unique designs of their products, to prevent mass (re)production by competitors.
Even if they are a discontinued item, they may still be protected legally. Better to find out beforehand, than find out the hard way later.
Unread 05-01-2009, 14:13
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Speaking of: http://dockets.justia.com/docket/cou...ase_id-220023/
I wonder if Poof-Slinky sued Blip over this very item, & that's why they are discontinued.
That would be true irony at it's finest.
What do you shop at for a similar store? Kmarts are minimal, Targets just kinda started popping up around here in the last 5 years I think, so what is your main store you shop at?
Also, 10 miles isn't that far. That's what, a 15 minute drive? (maybe 20 with dealing with the darn jughandles in your state, but still.. lol)
Then again, I drive 25 miles past 2 Walmarts on my way home & to work some days, so 10 miles isn't a big deal to me much anymore.
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
As long as they don't sell them they should be fine, maybe not legally but I doubt Blip toys is going to invest the time to prosecute anyone who makes these. I'm not saying it's right though.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 05-01-2009, 15:16
artdutra04's Avatar
We don't plan on selling them or making a profit off them in any way.
There are no patents or patent pending numbers listed on the commercial Orbit ball packaging.
Edit: The only thing a trademark or copyright can protect is the name, logo, etc. These are "interwoven, spandex-covered moon rock balls" for the 2009 FIRST Robotics Competition.
The design for these reproduction moon rock balls was only commenced because there was a need: the company discontinued production of a critical component (read: an interwoven, spandex-covered ball) needed for students participating in the goals of a non-profit organization.
And if they request that we remove the information because they have a valid reason (such as to protect an applicable patent) then we'll comply and delete anything applicable about this from the Internet. But if they do have any patents, and if the patent is unrelated to the design of the ball (such as if they patented the process by which a machine can mechanically weave the ball), then I don't see how it can affect this, since for this example these are made by hand.
So I figured let's help all teams; as this is something that can potentially help every team in the world achieve their goals of the FIRST Robotics Competition this year.
So if lawyers want to get involved and stop thousands of high school kids from successfully competing in a game made by a non-profit organization designed to inspire kids to science and technology, then they really have no soul.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-01-2009, 15:24
Art, great work on those "interwoven, spandex-covered moon rock balls!"
Let us know when that white paper is out.
Unread 05-01-2009, 21:16
R Stephenson's Avatar
R Stephenson R Stephenson is offline
ToolBelt
FRC #0871 (West Islip Robotecs)
R Stephenson is an unknown quantity at this point
FYI
http://www.logoloc.com/first/
Look at the right side
Unread 06-01-2009, 03:06
Chris Sturrock's Avatar
Chris Sturrock Chris Sturrock is offline
FRC #1503 (Spartonics)
Chris Sturrock is a name known to allChris Sturrock is a name known to allChris Sturrock is a name known to allChris Sturrock is a name known to allChris Sturrock is a name known to allChris Sturrock is a name known to all
Send a message via AIM to Chris Sturrock Send a message via MSN to Chris Sturrock
our team has come to the same conclusion. after searching nearby stores in both Niagara Falls Canada AND Niagara falls New York, a few of our members got to work on a scale model orbit ball which they made out of strips of plastic. we decided that it would probably just be easier to make a bunch ourselves.
Unread 06-01-2009, 06:54
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Is the white paper out yet? If so where?
Doug Leppard
Unread 06-01-2009, 09:25
BandChick's Avatar
AKA: Sara Reffler
Art will probably release it sometime today or tomorrow.
He waited for the official word on Orbit Balls before he chose whether or not to post it.
pic: orbit ball on head eeeeweeezeee Extra Discussion 6 18-01-2009 23:27
pic: Orbit Ball Packaging Tom Schindler Extra Discussion 19 06-01-2009 13:17
pic: Orbit Ball Packaging Tom Schindler Extra Discussion 0 03-01-2009 15:41
Coming soon: White paper on Crate generalbrando General Forum 8 13-02-2006 09:31
White Paper Discuss: Physics Analysis of a Ball Launcher coastertux Extra Discussion 0 01-02-2006 17:58
