Re: pic: Traction test
Both robots were running at full power. All wheels were slipping right from the start of the test. We also, to add another variable, added approx a 1/2 lb weight to each robot, the tandem wheeled robot, then the single wheeled robot. In each case, the single wheeled robot won the pushing match. We did notice about a 1 degree increase in surface temp of the wheels during the pushing mathces, which quickly dissipated upon shut down.
Tonight is the next phase, dual wheels and 1:3 on both robots. |
A few thoughts about this -
Given a perfectly level surface and a rigid chassis - how many contact points would there be on the 4 wheels vs 8 wheel? 3 points determine a plane. So, given that the chassis and wheel assembly might very well flex a bit, and the surface may not be perfectly flat - the # of contact points and the amount of force could vary between the 4 wheel and the 8 wheel. As stated earlier, the normal force will be divided among the number of contact points - contact points are more relavent in this case than surface area. I believe the difference that made the 4 wheel win, is due to the 4 wheel having more contact pressure per wheel in contact, and that the gearing reduction caused that machine to slip less than the 8 wheel. I know you indicated that both machine slipped right away, but I don't think that both slipped at the same rate. My guess is that the 4 wheel slipped slightly less. Just my 2 cents worth, Looks like you're having fun Mike Aubry |
| pic: Test/Training Bot | Rob2713g | Extra Discussion | 9 | 25-08-2007 15:37 |
| pic: Custom VEX Traction Wheel Rim | Chuck Glick | Extra Discussion | 20 | 03-10-2006 17:34 |
| pic: 1662's test tranny 5 | M4 Sherman | Technical Discussion | 4 | 17-06-2006 01:44 |
| pic: 1662 test tranny | M4 Sherman | Extra Discussion | 3 | 23-05-2006 18:02 |
| Results of traction test | IBApril180 | Technical Discussion | 3 | 04-01-2003 18:56 |
