Go to Post That's not duct tape as adhesive, it's duct tape as decoration! :p - Don Knight [more]
Unread 08-01-2009, 08:36
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: pic: Traction test
Originally Posted by Nuttyman54 View Post
...a single CIM could only input half the torque of two CIMs. Therefore, the single wheel accelerates better because it essentially has built in traction control, as it takes a lot more to put enough torque through the single wheel to slip it.
This sounds about right to me. Equate it to getting your car moving on a slick surface (ice). If you start in 1st gear you will most likely spin your wheels because the engine doesn't have to overcome much resistance to turn the wheels. Start in second gear and now your engine has to overcome the gearing before your wheels will spin. (This works great on a standard but not so easy to do with an automatic unless you have second gear start, my old '96 Grand Prix had it & it got me out of a few tricky spots.)
Unread 08-01-2009, 08:46
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Originally Posted by Rosiebotboss View Post
The robot on the right won every time. Why?
Static vs dynamic friction
Static inline 0.06
Dynamic inline 0.05
4 motors allows the wheel to reach top speed faster, then the two. The Cof, increases until it peaks at static, then approaches 0( or some value, that is less then static friction), as the wheel speed increases. Since the 4 motors reach top speed faster the can't exert their larger force, the 2 two can since they accelerate slower due to the lower torque.
Also, the force of fiction is Cof*P (pressure* Fiction) by having two wheels per side driven you decrease the pressure P (P=F/A, force/area), the force is the weight of robot, a large area will decrease your ability to move, by increasing the force of fiction. This also hurts the 4 motor design.
Thats two answers to your questions, heres the solution:
TCS, Traction Control System.
Is now an engineer thanks to FIRST.
Unread 08-01-2009, 12:17
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Are you using this year's acetal tread Rover wheels or some other variation?
It would be interesting to see the test results with this year's acetal tread Rover wheels on the FRP...
Unread 09-01-2009, 13:19
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Update:
We rebuilt the tandem wheeled robot to include a 1:3 gear ratio. So now both robots run at 300 rpm wheel speed. I didn't have my camera with me last night so I do not have any photos or video, but the single wheeled robot won the shoving match every time.
Conclusion: 4 wheel drive is the way we are going, maximizing stability and power to the ground.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 09-01-2009, 13:51
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Thanks for the update. We have a running discussing going here about whether having two wheels at each corner for a total of eight wheels is better than just a single wheel at each corner (total of 4). I say it doesn't help and that having a wheel at the center would do more good because it would take some of the weigth off of the corner wheels, which would help turn.
Brian K
Team 1225 Robotics Mentor
Unread 09-01-2009, 14:06
AKA: Dana P. Henry
There is a video posted on Youtube by the Nutrons, (Team 125 at Northeastern Univ) of them driving around their 2007 frame outfitted with the Rover wheels on a piece of FRP. Don't worry about unloading the corner wheels to facilitate turning!
Unread 09-01-2009, 14:16
Japper's Avatar
I couldn't help to notice that none of the videos on Youtube that have rover wheels appeared not to be weighted down to simulate the typical 150 pound robot .. the actual weight factor may affect how these rover wheels perform on that surface...
Also, I wonder if the conditions of that field service will get better as one and one half days of robots drivinig on them during the competition...
Hopefully we will have our practice field ready for testing tonight...
pic: Test/Training Bot Rob2713g Extra Discussion 9 25-08-2007 15:37
pic: Custom VEX Traction Wheel Rim Chuck Glick Extra Discussion 20 03-10-2006 17:34
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: 1662 test tranny M4 Sherman Extra Discussion 3 23-05-2006 18:02
Results of traction test IBApril180 Technical Discussion 3 04-01-2003 18:56
