Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Unread 01-10-2009, 08:01 PM
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
pic: Whats going on HERE?
Unread 01-10-2009, 08:03 PM
CraigHickman
Re: pic: Whats going on HERE?
I'm curious... What sort of numbers have you done on the plastic worm gears, and the amount of weight they're going to take? If I recall from my own off season tests, they aren't the strongest things out there...
Also, how are you going to deal with wire twisting? Are we allowed 4 window motors, and have you bought 2 more of the current years? We're not allowed any of the previous years, as far as my understanding goes.
gorrilla's Avatar
AKA: adam spears
swerve drive perhaps
really dident take that long to build 4 of them, we found these wonderful boxes that were just the right size.....
we put them under our 2008 robot and the worked great,
only about 40 pounds of pressure on them i believe, there just prototypes(our first directly driven wheel) we have other more powerful motors that we could switch them out for quickly if they dont hold up, only six motors used total(4 for driving wheels and two for turning them)
as for the wires,thats something we'll have to figure out later
ps.. it may or may not be, based off your cad you posted awhile back.....
Adam Spears
2010: Goveners Award.
2010: UL Saftey award.
Unread 01-10-2009, 08:08 PM
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Sam2197 will become famous soon enough
ya have to wonder... what are the cims being used for????
Unread 01-10-2009, 08:10 PM
gorrilla's Avatar
AKA: adam spears
thats a suprise.......but i can tell you that thier needed(badly) in other places.... which is why we went for the window motors
Adam Spears
Unread 01-10-2009, 08:13 PM
CraigHickman
I'm confused as to how this could be based off my CAD. I've never done a direct drive, nor would I ever consider it. If something breaks in this module, the entire thing needs to come apart to change it.
The use of thin plate for a module will allow it to flex a hefty amount, and deflection isn't good. A tiny amount as small as .125" of deflection will take your wheel's contact patch down by somewhere around 60%, depending on the size. If it's not rigid, you lose HUGE amounts of efficiency when turning.
As far as strength of the Window motors, keep us posted on how they do.
Unread 01-10-2009, 08:22 PM
gorrilla's Avatar
AKA: adam spears
well the box(mostly inspiriationaly)
actually it dosent all have to come apart....the way we built it, the motor is bolted to the outside of the box, the hub is attached to the output gear, the hub is attached to the wheel, and a 1.5inch 3/8th bolt is put through a bearing which is then bolted to the other side
to remove the entire motor and wheel and replace it, takes about 3 minutes
yeah, the plate is pretty thin, we are waiting for comformation if a local machine shop can make us some thinker ones(say 1/8inch alluminum?)
pretty much, it was built to be as cheap and simple as possible(as i said its our first time Not using tank drive) we're feeling pretty ambisious this year
ps.. we have 4 window motors for driving the wheels, and we have 2 other motors that came in the kit(not sure what they are, like a bigger more metalic version of the window motor?)
Adam Spears
Unread 01-10-2009, 08:29 PM
Can you link to the exact one please? I don't see the point of this design btw, what exactly is the point?
Unread 01-10-2009, 08:31 PM
CraigHickman
Hey, just keep an eye on this:
<R51> Motors specifically permitted on 2009 FRC ROBOTS include:
A. All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and
maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB
servos, as provided in the Kit Of Parts),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM
motors can be used on the ROBOT.
I'm not sure how you plan to drive your robot with 4 of a motor that we're only allowed to use 2 of...
Unread 01-10-2009, 08:32 PM
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Sorry to bear some bad news...
<R52> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with
the exception of those specifically permitted by Rule <R51>.
You only get two window motors (1 of each orientation) in the KoP so this setup is not legal.
Unread 01-10-2009, 08:34 PM
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
You need to check that you are not violating the window motor count.
One left and one right denso motor was in the KOP, providing two
motors, not four.
Eugene
Unread 01-10-2009, 08:35 PM
gorrilla's Avatar
AKA: adam spears
yeah we saw that, we'll have to work something out(not to hard to get around)
oh, this one http://www.chiefdelphi.com/media/photos/28443
they were going to be v-shaped originally, but then we found those boxes...... and its the same tring setup to(with the sprocket up top)
and we know, we can only use two window motors, theres these other ones that are bigger that we are trying to make work
Adam Spears
Unread 01-10-2009, 08:39 PM
CraigHickman
So there aren't 4 of them. There's two separate kinds. How are you planning to keep the robot speed constant with two different wheel speeds?
Unread 01-10-2009, 08:46 PM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm confused as to how this would work. If they are indeed crab modules you have 2 Denso Window Motors (1 left, 1 right) and 1 Keyang motor to work with with similar form factors.
What motors are you planning on using?
gorrilla's Avatar
AKA: adam spears
on the prototype there are(sorry if i dident make that clear)
the window motors are 90pm and the other ones are like 85 so it shouldent make that much of a difference(i hope) any suggestions?
we could also use the globe motors if we have to.....
just what we had lying around is what we used...the final version will absolutely be legal...
another reason for the swerve drive is that a tank drive wont turn the robot(so we thought why turn the robot, when we could turn the wheels?)
Adam Spears
pic: What's going on here? CraigHickman Extra Discussion 22 01-13-2009 10:24 PM
pic: Whats in here...? CD47-Bot Robot Showcase 5 02-21-2004 05:12 PM
Whats going on at Lone Star? Team238-aholic Regional Competitions 17 04-09-2003 05:28 PM
Whats going on!!!!! Useless member General Forum 4 01-05-2003 06:19 PM
whats it going to take to win? mike pawlak Chit-Chat 6 04-17-2002 10:39 PM
