#16
Re: pic: Whats going on HERE?
Tank drive turns just fine for us....not to mention many others. |
#17
on the FRP? with the trailer? our 2007 robot wouldent turn at all.......maybe its just us.... |
#18
Did you have your weight distributed properly across the entire base and over the four wheels? If not, then that's part of the problem. I'd suggest retrying that before you take a drastic design risk such as this. But that is just a suggestion. |
#19
you know thats not bad if you use those in the front to start and then kick in two cims after you get some speed to avoid doing a burnout almost like a two speed tranny
let me just take a guess since cims are designed to continously run and window motors are not i would guess that you are using the cims to run a ball herding mechanism and using the window motors for drivetrain |
#20
you could just back up into the trailer and have the bumpers start the turn for you
#21
we had it in low gear(AM Gen2's) the wheels were just spinning(tried slowly accelerating and getting up to speed and trying to whip it around, to no avail)may be some other factor we're missing? |
#22
Depends on the trailer orientation too. |
#23
we cant get any pool noodles as its winter and there out of season....though when we did back up it jackknifed and made it slowly(SLOWLY) turn around halfway before it got in line with the robot
#24
Also something else to think about is that your robot is going to travel at about 2fps if you direct drive off of the window motors. |
#25
anyways.....its still a prototype |
#26
This year's game does not benefit from torque...like, at all. Just explain the purpose of this to me. Thanks. If you decide to continue with the prototype or follow through with it, then I wish you good luck. |
#27
Approximately how far apart are your wheels on the frame? With a 4 wheel drive skid steer, with the wheel centers about 30ish inches apart on the axis on the long dimension, and 22ish on the width dimension, our robot turned. We too had AM Gen2 shifters in low gear. We tried both pinning it and a gradual acceleration. In both cases it turned, although not particularly well. (Gradual acceleration turned better than pinning it)
#28
We have a 4wd long test base and it turns fine on linoleum floor (no regolith); just make sure the wheels aren't spinning before executing a tight turn. I cut throttle before turning, can easily do a 180+ spin. We don't have a trailer yet but Dave Lavery made a post on here about exploiting the trailer to turn quickly.
#29
But even if thats wrong 4-6fps is still really slow for an FRC field. It would take you 10 seconds or more to cross the field at that speed |
#30
btw, I checked Dustin's math...and its correct. |
| pic: What's going on here? | CraigHickman | Extra Discussion | 22 | 01-13-2009 10:24 PM |
| pic: Whats in here...? | CD47-Bot | Robot Showcase | 5 | 02-21-2004 05:12 PM |
| Whats going on at Lone Star? | Team238-aholic | Regional Competitions | 17 | 04-09-2003 05:28 PM |
| Whats going on!!!!! | Useless member | General Forum | 4 | 01-05-2003 06:19 PM |
| whats it going to take to win? | mike pawlak | Chit-Chat | 6 | 04-17-2002 10:39 PM |
