Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
  #31   Spotlight this post!
Unread 01-10-2009, 09:15 PM
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
Re: pic: Whats going on HERE?
Still don't see the point in this design.
This year's game does not benefit from torque...like, at all.
Just explain the purpose of this to me. Thanks.
If you decide to continue with the prototype or follow through with it, then I wish you good luck.
not so much torque, with the cims(going full on, out a toughbox) the wheels just spun and spun untill the forward momentum overtook the spinning and it went forward(about 4 seconds) we wanted to test soMething that we could just drive around and not have to worry about "easing it on" with the window motors theres' almost no slipping and nearly instant acceleration(yes we've done our math)
Originally Posted by iCurtis View Post
Approximately how far apart are your wheels on the frame? With a 4 wheel drive skid steer, with the wheel centers about 30ish inches apart on the axis on the long dimension, and 22ish on the width dimension, our robot turned. We too had AM Gen2 shifters in low gear. We tried both pinning it and a gradual acceleration. In both cases it turned, although not particularly well. (Gradual acceleration turned better than pinning it)
hmm, that exactly how we had our setup...ill make sure to test it again on monday to see whats wrong(seeing as so many peoples robots could turn) i wonder what could be causing our problems?
Adam Spears
2010: Goveners Award.
2010: UL Saftey award.
  #32   Spotlight this post!
Unread 01-10-2009, 09:16 PM
Originally Posted by gorrilla View Post
going full on
There's your problem right there.
  #33   Spotlight this post!
Unread 01-10-2009, 09:19 PM
gorrilla's Avatar
AKA: adam spears
i know, but in the heat of the game, i'd want to be able to have as much control as possible as quickly as possible
and about the math, I dont know, but its definately faster than 2.3 fps....(maybe we had a strong tailwind)
and if we find out this wont work, its not that hard to switch to tank drive.....
Adam Spears
  #34   Spotlight this post!
Unread 01-10-2009, 09:22 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
The thing is in the heat of the moment you'd just need to control your acceleration a bit. Make your acceleration progressive like go 25% then 50% then 100% throttle. Once you're moving a little bit you'll be less likely to spin wheels. And trust me, you'd rather spin wheels a bit and go 10fps than not and be limited to 4fps.
-Dustin Benedict
  #35   Spotlight this post!
Unread 01-10-2009, 09:25 PM
gorrilla's Avatar
AKA: adam spears
this could also be done in programming easily, if we decide to use a tank drive....we'd only have two cims(shouldent make any difference as the kickoff showed)
basically, we could do anything, its only the second week now....just prototyping i'd thought id share
Adam Spears
  #36   Spotlight this post!
Unread 01-10-2009, 09:27 PM
Using a tank drive (skid steering) on a drivetrain built like a swerve seems to defeat the purpose, doesn't it?
o wait nvm i think i interpreted that wrong.
And yup, sorry to sound like we're bashing your design, just giving criticism. After all, that is the point of posting prototypes on here.
  #37   Spotlight this post!
thefro526's Avatar
Mentor for Hire.
Precisely, thats a good idea.... We're probably going to implement that as well. If you do a tank drive with a progressive acceleration then there's no need for a window powered swerve.
-Dustin Benedict
  #38   Spotlight this post!
Unread 01-10-2009, 09:34 PM
gorrilla's Avatar
AKA: adam spears
yeah, what ever desicions we make in the next week for our shooter/harvester design, will probobly cement our drivetrain to one or the other.....
we could,just make a swere work with the 2 cims and have only 2 modules in the front? wouldent be as easy to steer though
Adam Spears
  #39   Spotlight this post!
Unread 01-10-2009, 09:36 PM
It might be a fun thing to try in the offseason, but if I were you I wouldn't risk spending that time and energy especially in the first 2 weeks of build. Some don't realize this, but loss of time doing something a bit odd can cost you a lot more than doing something crazy in like week 3 or 4.
If I understand correctly, you'd just want the front two to be turning? Why not just make something like ackerman ("car steering") then?
  #40   Spotlight this post!
Unread 01-10-2009, 09:40 PM
thefro526's Avatar
Mentor for Hire.
Stogi Speaks the truth here.
It's better to spend an extra day thinking before you start building and make the best decision possible than to commit to a risky design like this and loose a week when it doesn't work.
That being said it's not a bad concept it just might not work for this game. The window motors would put a severe handicap on your speed and may not be robust enough for a robot's drive train.
-Dustin Benedict
  #41   Spotlight this post!
Unread 01-10-2009, 09:41 PM
gorrilla's Avatar
AKA: adam spears
well that way there powered also, and we could just use two of what we have with some minor modification.....
and so far we've only spent two days on it, out of the week ....if you'all think its such a bad decision..its not that hard to just switch to something else...
as for time...its amazing what can be done in 4 hours when everybody is highly motavated and energized........
i remember last year, on the day before shipping, at 8:30 at night, we completely changed our drivebase from 4wd to 2wd with a castor and a unpowered wheel....
ps. this is what prototyping is for....
Adam Spears
pic: What's going on here? CraigHickman Extra Discussion 22 01-13-2009 10:24 PM
pic: Whats in here...? CD47-Bot Robot Showcase 5 02-21-2004 05:12 PM
Whats going on at Lone Star? Team238-aholic Regional Competitions 17 04-09-2003 05:28 PM
Whats going on!!!!! Useless member General Forum 4 01-05-2003 06:19 PM
whats it going to take to win? mike pawlak Chit-Chat 6 04-17-2002 10:39 PM
