Go to Post IMO the main idea behind FIRST is for the mentors and students to work together to produce a machine that the students could never have produced on their own. - Tim Sharp [more]
Unread 11-01-2009, 06:52
GaryVoshol's Avatar
Cogito ergo arbitro
Re: pic: Carmen week1 team 842
Oh, oh. Check the bumper rules. You can't attach a legal standard bumper to those angled faces in front.
(since 2004)
Unread 11-01-2009, 08:07
thehurd03's Avatar
thehurd03 thehurd03 is offline
Joel H.
FRC #0470 (Alpha Omega)
thehurd03 is on a distinguished road
Send a message via AIM to thehurd03
They don't have to, The rules say you have to cover 75% (I think) of the perimeter of your robot.
Unread 11-01-2009, 09:10
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
2/3, but they also must cover all corners.
It looks rather impressive. Excellent progress for week 1! Good job.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 11-01-2009, 09:14
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
I would worry about bumper rule I:
BUMPERS must protect all exterior corners of the BUMPER PERIMETER
in combination with bumper rule A:
BUMPERS must be built in segments, with a minimum length of six inches, and a maximum
length that does not exceed the maximum horizontal dimension of the ROBOT
So if you need to have a bumper on the front (that's the if), it must be 6 inches long and fastened to the hard robot frame, which in the pictured robot's configuration would put it inside the bumper perimeter and thus illegal according to bumper rule L:
The BUMPERS must be fixed to the BUMPER PERIMETER
Unread 11-01-2009, 12:15
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
Does the bumper perimeter have to be rectangular? We are planning on running the bumper into our bot six inches.
Just for example... what if you had an L shaped robot?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 11-01-2009, 13:11
NickE's Avatar
NickE NickE is offline
_
Where's the cRIO?
Originally Posted by 2009 FRC Manual Section 8.2
BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS or Trailer Hitch attached) that are within the BUMPER ZONE. To determine the BUMPER PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
i.e. The bumper perimeter must be a convex polygon.
Unread 11-01-2009, 13:16
AKA: Ledge
Originally Posted by NickE View Post
Where do the cRio and Spikes go? i.e. The bumper perimeter must be a convex polygon.
That is interesting, where does it say that it must be convex?
That would settle the dispute......
Thanks for helping to vet us. We don't want to caught at a regional with a violation.
Unread 11-01-2009, 13:27
NickE's Avatar
_
It never explicitly says that it must be convex, but wrapping a string around a concave polygon will result with the string not following the entire perimeter of the polygon. If you wrap a string around this robot in the bumper zone, it will form a convex rectangle.
Unread 11-01-2009, 13:47
AKA: Ledge
definition per rules
We would have our string cross the opening of our bot. It does not say it has to make contact with the bumper zone everywhere. That is an assumption. Our polygon would be a rectangle, never the less we will cover the angles in from the corner with 6 inches of bumper. We think we are ok......I hope
Unread 11-01-2009, 13:49
NickE's Avatar
_
Would the bumpers be straight (parallel with back of bot) or angled (parallel with angled front sides of bot)?
Unread 11-01-2009, 16:19
AKA: Ledge
angled
Unread 11-01-2009, 22:50
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Angled "bumpers" would not pass inspection because technically they are not bumpers at all since they do not lie on the bumper perimeter according to the current set of definitions and both sides of the corner must be protected.
Unread 11-01-2009, 22:57
MrForbes MrForbes is offline
Ahhh...here's that statement that seemed to me to be missing from the rules.
"2. As indicated in Rule <R08-I>, all exterior corners of the BUMPER PERIMETER must be protected by BUMPERS. Both "sides" of the corner must be protected."
from http://forums.usfirst.org/showthread.php?t=11159
Unread 11-01-2009, 13:52
I believe the intent is that bumpers must be on the bumper perimeter. You're taking a risky move, and should probably Q&A it.
Unread 11-01-2009, 14:04
GaryVoshol's Avatar
Cogito ergo arbitro
It's not just the intent, it's the rule:
Originally Posted by <R08>
L. The BUMPERS must be fixed to the BUMPER PERIMETER.
What needs to be answered in Q&A is if every side of your robot must have bumpers in order to satisfy the requirement that corners are protected.
(since 2004)
pic: Robot-Week1 Brad Voracek Extra Discussion 13 16-01-2009 11:44
pic: Team 842 in Hispanic Magazine falconmaster Extra Discussion 5 07-10-2008 19:28
pic: 1889 Team HAZE's frame (week1) Tytus Gerrish Extra Discussion 8 19-01-2007 02:23
pic: installed battery team 842 falconmaster Robot Showcase 11 04-02-2006 09:36
pic: Turret team 842 falconmaster Robot Showcase 3 01-02-2006 17:28
