Go to Post I tried to make them look at disgruntled as possible. - Katie_UPS [more]
Unread 13-01-2009, 08:09
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Re: pic: 2009 Lunacy Field
Originally Posted by JB987 View Post
Has anyone noticed that their regolith panels tend to pucker up where taped at all seams? And yes, we are using the recommended tape. If no problem, did you also tape the underside, use double sided tape on bottom or use other method?
The tape that you see on top of the panels is the only thing that is holding the panels in place. We considered using double-sided tape or velcro on the underside but decided that the tape on top of the panels would suffice. When we laid the panels down, we left hardly any gap between the panels. So far there has been little or no "bumps" in the field where two panels meet.
paper: 2009 Lunacy Scoring Spreadsheet cbudrecki Extra Discussion 7 12-01-2009 00:04
Lunacy playing field. Captain banana General Forum 2 10-01-2009 18:31
2009 Lunacy Trailer... HELP Daniel Krastev General Forum 4 10-01-2009 09:13
2009 Lunacy Q&A Forum on FIRST's website Russ Beavis Rules/Strategy 0 09-01-2009 16:41
FRC 2009 - Lunacy Michelle Celio General Forum 47 05-01-2009 14:57
