Go to Post Turning is overrated - Allison [more]
Unread 13-01-2009, 13:54
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
paper: 2009 Motor Data
2009 Motor Data by kramarczyk
Unread 13-01-2009, 13:55
Re: paper: 2009 Motor Data
Where is the Banebots 545 specification from? It is significantly different than the specification provided on this page.
Unread 13-01-2009, 14:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The quantities aren't correct either. There's two FP motors in the kit, as usual.
Unread 13-01-2009, 14:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The RS-545 data there is for an older motor supplied by Mabuchi. The 2009 RS-545 motor is similar-looking, but not manufactured by Mabuchi, and has different specifications.
Also, I was playing with the spreadsheet, and noticed that the "At max. efficiency", "Normal rated load", and "At max. power" rows don't do anything, and actually only contain information for one particular motor.
And I'm not exactly sure what's going on here, because BaneBots lists Kv = 1400 rev/(min·V), which works out to Ke = 0.00682 V·s/rad. The spreadsheet calculates Kv = 0.006529 V·s/rad. Similarly, BaneBots quotes Kt = 0.0079 N·m/A, while the spreadsheet returns Kt = 0.00581 N·m/A. (These constants affect pretty much everything.) I had a quick look at Mark's math, and it looks right, so I'd have to guess that BaneBots may not have the correct values for something. (But are their given speeds, currents, etc. correct, or their constants?)
Unread 13-01-2009, 15:07
The motor curves generated by this spreadsheet aren't correct. Or they're only correct when you have the reference voltage set to 12V, or whatever the reference voltage was on the data sheet. Changing the reference voltage doesn't change the max current, stall torque, max power, or generally anything that it should. The "calculated" motor data the plots are based on doesn't calculate the stall torque from Kt, V, and R, it only looks it up from the motor data table.
I think this spreadsheet should be considered a beta version at this point, as there are more than a few things about it that seem inaccurate.
Unread 14-01-2009, 07:21
kramarczyk's Avatar
I was not aware of that, thanks.
Yeah, at this point it is clear that I bungled this one... nothing for me to do now, but fix it. Thanks for the feedback.
Mark
Brick walls are for other people. - Randy Pausch
Unread 14-01-2010, 11:44
kramarczyk's Avatar
I totally forgot about this needing to be worked on. I'll get on it.
Mark
Unread 18-01-2010, 11:18
kramarczyk's Avatar
Updated in 2010 version at http://www.chiefdelphi.com/media/papers/2320?
Mark
paper: 2009 Lunacy Scoring Spreadsheet cbudrecki Extra Discussion 7 12-01-2009 00:04
Interpreting motor data John Gutmann Motors 6 21-03-2007 09:55
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
