Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 13-01-2009, 13:55
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: 816's 2009 Drivetrain!
Are the chain runs shown in the picture temporary or are you just using the extra drive sprockets as temporary spacers?
Or I suppose they could be for attaching some unknown mechanism to the drive transmissions.
Unread 13-01-2009, 14:45
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
We are building a very similar chassis for prototyping. Just curious, did you test this 6WD configuration against a 4WD configuration (like the one in the picture, but without the middle wheels)? We're planning to, just wondering if there are any substantial advantages to either design.
Comments?
Unread 13-01-2009, 18:35
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Comments?
Nope we went straight to the 6WD as far as I know. Unless they did it when I wasnt there which isn't much.
Unread 13-01-2009, 20:48
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally I designed it so that the front chain went all the way back to the transmission. Then after we started putting the chains on we noticed that we didn't really need it so we shortened the chain up. The only reason the sprocket was still on the was because we didn't get a chance to make a spacer yet.
Comments?
I don't think it would be substantially different aside from the fact that your distributing your weight over 6 points instead of 4 which can cause the robot to maneuver differently. I have a personal preference towards 6 wheel drives and that's kinda why we went in this direction. You should be fine with a 4 wheel drive with similar geometry and then if you wanted to you could always add a 5th and 6th wheel
-Dustin Benedict
Unread 13-01-2009, 21:02
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
First of all, i like the zip-tied battery But this is pretty awesome. We've got a four wheel base with the same orientation. I was just wondering how the one cim was goin for you with six wheels. Last time we drove with six wheels, it was easier to use two cims and we were able to maneuver better.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 13-01-2009, 21:09
thefro526's Avatar
Mentor for Hire.
This year we decided that it didn't offer much of an advantage because with the traction available we're only going to be able to put down about 9lbs of force before the wheels slip. Also because there's less friction against the drive in general and it requires less force to turn we deemed the second motor unnecessary. If we ever needed to we could always bolt a second motor into the tough box without much trouble.
-Dustin Benedict
Unread 13-01-2009, 23:47
Looks good Dustin. Can it push MORT around though?
Unread 14-01-2009, 19:05
amariealbrecht's Avatar
amariealbrecht amariealbrecht is offline
Alicia Albrecht
FRC #2177 (The Robettes)
Team Role: Electrical
amariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura about
Send a message via AIM to amariealbrecht
Cool Re: pic: 816's 2009 Drivetrain!
very impressive...
Unread 14-01-2009, 21:32
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
How is the turning on your bot?
pic: Team 612: 2009 Drivetrain Teaser nahstobor Extra Discussion 7 04-01-2009 03:13
816's Robot as of 2/2/08 thefro526 Robot Showcase 30 20-02-2008 15:34
816's Completed Robot!!! thefro526 Robot Showcase 13 19-02-2008 21:24
pic: 816's hybrid teaser!! thefro526 Extra Discussion 6 09-02-2008 22:10
pic: 816's First Teaser thefro526 Extra Discussion 5 02-02-2008 19:56
