Go to Post Never quit, never give up, never say die! - Cascade [more]
Unread 14-01-2009, 14:47
Data Nerd
FRC #0079
pic: 397 Bumper Configuration
Unread 14-01-2009, 14:50
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: pic: 397 Bumper Configuration
it is as long as each segment of the bumper is at least 6'' long, at least that's what i think.
oh and you need an opening for the trailer hitch to feet in.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 14-01-2009, 14:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ok, I'm not sure exactly where in the drawing you are planning on putting bumpers. Having said that I believe you could make a legal configuration out of this frame provided the two front flat surfaces are 6" long each.
Assuming the robot is 28X38 your bumper perimeter is 132" and yoiu need to cover 88" with bumpers.
It appears that there would be no reason not to cover both long sides with this design giving you 76". To properly cover the corners you would then need 2 6" segments on each of the short sides for a total of 24" which brings you well over the required 88".
If the angled pieces on the front are supposed to be bumpers these are not "official" bumpers and would count for robot weight and volume (and this cannot extend outside the bumper perimeter and would be illegal in the configuration shown. Removing these bumpers (and enough in the back to make a space for the trailer hitch would result in a legal configuration.
Unread 14-01-2009, 14:55
If the two angled front pieces are bumpers, this is illegal. Bumpers must be on the bumper perimeter, which is defined by wrapping a string around the robot.
Unread 14-01-2009, 14:58
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Post Re: pic: 397 Bumper Configuration
It looks to me like you have a short bumper segment on the front end that curves into some sort of picker-upper device. According to my interpretation of <R08>, the bumper segments that angle into your picker-upper are not legal bumpers because they are not on the bumper perimeter. Additionally, the front segments look a little short - the plywood backing needs to be at least 6" long.
My team actually had a discussion about a similar area on our robot last night!
Hopefully this helps you out.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 14-01-2009, 15:03
HUNT397's Avatar
HUNT397 HUNT397 is offline
AKA: Chris Hunt
FRC #0397 (Knight Riders)
HUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to behold
The angled sections are 6in long and we were going to put them there to satisify the corner bumper rule. and oops i did forget to add the hole for the trailer. So if we removed the small section would that be legal even though <R08> I. BUMPERS must protect all exterior corners of the BUMPER PERIMETER. is not satisified?
Unread 14-01-2009, 15:06
EricH EricH is offline
If you removed the angled sections and the rest in that area was 6" long or more, you'd probably be fine.
The one thing I'm wondering is--are bumpers allowed inside the robot's BUMPER PERIMETER, if they aren't treated as BUMPERS?
Unread 14-01-2009, 15:13
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Ok, so…
I'm going to say no, since the segments of the front bumpers that lie on the two diagonals won't be considered BUMPERS, since they don't lie on the BUMPER PERIMETER. (<R08>L)
Also, ignoring the diagonal bumpers, the two segments on the front BUMPER PERIMETER look to be too short (min. 6") to qualify as BUMPERS. (<R08>A)
Keep in mind my response is not official in any way.
Unread 14-01-2009, 15:16
Data Nerd
FRC #0079
Yeah, I was wondering that myself. My only question is how does that work with polygons with 5 or more vertexes? Rather than try to illustrate with text I will give you points to plot, if I have a polygon with vertexes A= (0,0) B=(0,10) C=(10,10) D=(5,5) and E=(10,0) We know point D does not fall along the bumper perimeter. By your own argument the BP would be a polygon bounded by by ABCE. My primary question is that the rule states "BUMPERS must protect all exterior corners of the BUMPER PERIMETER (see Figure 8 - 2). " (From R08 I) The corner formed by BCE needs to be protected but obviously we cannot because there is no frame there. The logical thing would to run bumpers across angle BCD but as you said this is illegal because CD is not along the bumper perimeter.
Unread 14-01-2009, 15:17
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Bumpers not attached to the BP would have to be counted as part of the robot (including weight).
<R08>
L. The BUMPERS must be fixed to the BUMPER PERIMETER.
-Oris-
Unread 14-01-2009, 15:20
FF - PureMichigan
The Bumpers must protect all the exterior corners of the BP not necessarily the corners of the robot frame.
-Oris-
Unread 14-01-2009, 15:59
MrForbes MrForbes is offline
From all the hours I've spent reading on this subject, I'll agree with Adam, it's not legal, you need to have 6" minimum bumpers on the front, not angled back. It's the combination of the Q&A response that you need BUMPERS on both sides of each corner of the BP, the rule that BUMPERS must attach at the BUMPER PERIMETER, and the minimum length of 6".
Wide robots are looking pretty good this year.
Unread 14-01-2009, 17:09
GaryVoshol's Avatar
Cogito ergo arbitro
Non-standard bumpers could be included on the angled faces leading to your collector if you desired. They would not have to meet any BUMPER standards, but would be counted in size and weight of the robot.
The short front sections of the robot must be protected with Standard BUMPERS. Part of the requirement of those is that the combined section of plywood, noodles and cloth must be at least 6" long, and not extend past the exterior corner of the robot. (Noodles and cloth alone can - in fact MUST - extend past the frame to protect the corner.) The entire length of the BUMPER must be supported by the main frame.
(since 2004)
Unread 14-01-2009, 17:29
Jared Russell's Avatar
Taking a year (mostly) off
I have deleted this post because of my (now) better judgement.
Unread 14-01-2009, 22:15
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It'd be pretty upsetting if the GDC reverses what they've already stated very clearly. All corners, both sides, 6 inches. It's intent has been pretty clear in the rules. That still leaves you 16 inches on a long robot to get a ball.
"Wrapping" the string so it touches just the outside edges of your robot and defining that as the bumper perimeter has been pretty well understood too (in my opinion).
If this suddenly changes to allow teams more leeway, other teams that have made serious design decisions that can't be changed would be rather disadvantaged.
pic: Legal Bumper Configuration? AdamHeard Extra Discussion 31 15-01-2009 03:15
pic: Team 397 2008 Robot 100% done!! HUNT397 Extra Discussion 9 14-02-2008 14:24
Thanks 397 dan 322 Thanks and/or Congrats 1 12-03-2006 09:10
pic: 397 Final product HUNT397 Robot Showcase 0 24-02-2006 18:57
