Thread Tools |
Rating:
Display Modes |
Re: paper: Reading the FTC Battery Voltage
These are in addition to what you got when you did the initial FTC LabVIEW install. Most of these VI's are used to access the Motor Control Encoders (or encoder related functions). They are part of the "FTC Toolkit". The update is referenced on the FIRST FTC page: http://www.usfirst.org/community/ftc...t.aspx?id=6650 Go to this page in the NI site to see the available updates: http://zone.ni.com/devzone/cda/tut/p/id/7956 In particular is this update page: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1129 You want the update file called: lv_ftc_motors_nov1708.zip After downloading, you must follow the direction at the bottom of the page to install them. It requires you to unzip the files and copy them to a folder contained in the LabVIEW program folder. c:\program files\LabVIEW 8.5\vi.lib\addons\FTC Toolkit This should now give you a new sub-pallette called "FTC Motor Encoder Functions" That's where all the controls are that I use as part of my control. Phil. |
| [FTC]: Reading the 12V Battery voltage in LabVIEW | PhilBot | FIRST Tech Challenge | 7 | 12-01-2009 21:13 |
| [FTC]: [FTC]: Replacing Fuse for Battery | fqzeng | FIRST Tech Challenge | 4 | 18-11-2008 20:04 |
| The 8.2 (or 8.3) Battery Voltage Bug | eugenebrooks | Programming | 167 | 21-02-2008 20:05 |
| Reading battery voltage in software | RbtGal1351 | Programming | 17 | 21-10-2007 13:07 |
| Battery voltage | Josh Siegel | Programming | 5 | 22-12-2003 10:15 |
