Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 15-01-2009, 02:10
Susha's Avatar
Susha Susha is offline
FRC #2177 (Robettes)
Team Role: Electrical
Susha is an unknown quantity at this point
Talking Re: pic: Team 1382 Eletronics Board
The baord looks great! We're going to be using the C-channels as well so it's nice to see how and how well they work.
Unread 15-01-2009, 02:23
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Does look nice for bench testing, but you might want to seperate your data (unshielded PWM, Ethernet, ect.) lines from your power lines. EMI is a pesky pixie.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 15-01-2009, 02:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by Teja View Post
first of all...great looking e-board! i was just wondering how you mounted the crio onto the board. I looked arround and they dont really give any like mounting holes.
The mounting holes are obscured by the modules when they are installed. Remove the modules and the holes magically appear
Unread 15-01-2009, 11:07
Teja's Avatar
Teja Teja is offline
AKA: TejaChill
FRC #0540 (Talon 540)
Teja is on a distinguished road
woah!! gotcha....thanks for the help. We did some testing and i had to use a bunch of zipties to mount it.
Unread 15-01-2009, 11:14
Electrical1764's Avatar
Electrical1764 Electrical1764 is offline
Cambiano
FRC #1764
Electrical1764 is an unknown quantity at this point
I like the look of this board, and the organization, but what happens when a wire has to be replaced? It just seems to me that it would take longer to replace a wire with all the holes to weave through and the zipties.
If You Can't take the heat, step away from the robot!!!
"You shut your mouth when you talk to me!"
Unread 15-01-2009, 18:29
Felipe Sagui Felipe Sagui is offline
FRC #1382 (EtepTeam)
Felipe Sagui is an unknown quantity at this point
Send a message via MSN to Felipe Sagui
when a wire need to be replaced we open and take off the wire with problem...it's easy...only need to get the correct wire with a multimeter.
Felipe Cezar Salgado
ETEPTEAM #1382
Unread 15-01-2009, 18:46
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
If you take the cartridges out of the Crio and look hard enough you will find some mounting holes. It is rather annoying though...
Unread 15-01-2009, 18:57
mynameisbob's Avatar
mynameisbob mynameisbob is offline
Electroblaster
FRC #2422 (Bucket-o-bolts "BOB")
mynameisbob is an unknown quantity at this point
Send a message via Yahoo to mynameisbob
yes they do, their in the bottom in the place where you put the removable units. you have to remove them first.
Bucket O' Bolts
team 2422
My name is BoB!
http://www.bucket-o-bolts.com
"Its better to be thought an idiot than to open your mouth and remove all doubt!"
pic: 1382 Brazil Prototype + Electronic Board tribotec_ca88 Extra Discussion 1 29-01-2005 15:54
pic: Team 1382 BrAZiL at work!!! Mandi_|<o>| Extra Discussion 2 26-01-2005 22:41
pic: Team 1382 Brazil - Field tribotec_ca88 Extra Discussion 2 20-01-2005 14:36
pic: Team 1382 Brazilian hangs CD47-Bot Extra Discussion 2 08-03-2004 22:09
pic: Team 1382 (Brazil) Robot!!! CD47-Bot Robot Showcase 1 23-02-2004 11:30
