Go to Post There's lots of other "stuff" that make a team work well in the FIRST environment, beyond designing and building a robot. - KathieK [more]
Unread 16-01-2009, 08:51
TestEngr571 TestEngr571 is offline
AKA: Dana Susca
FRC #0571 (Team Paragon #571)
Team Role: Electrical
TestEngr571 will become famous soon enough
Re: pic: Electrical
We too are waiting for our mechanical team to give us the footprint allowed for our electronics this year. Our team has fabricated a removeable electronic and pneumatic control box ( the "ElectroPneumaQuarium") for the past two years and would like to do so again, but may not be able to this year due to chassis constraints.
From your picture I noticed a slight problem in your wiring. The +12volt port to the left of the +24v connection on the PDB is meant for the wireless bridge, not digital sidecar power. This will work, but it is not per the power distribution diagram in the manual. You should power the digital sidecar with +12volts from one of the lower current WAGO outputs (30A-20A) as you did for the solenoid and analog modules.
Good Luck!
Dana Susca
FRC Team #571 Electrical Mentor
pic: 2080 Electrical box pic 4 Torboticsmember Extra Discussion 0 08-02-2008 13:19
pic: 1323 electrical Robo_Coyote Extra Discussion 1 20-01-2007 19:32
pic: electrical plan Stats Extra Discussion 0 19-02-2006 02:01
pic: 1240 Electrical zdeswarte Robot Showcase 3 01-03-2005 14:33
pic: Electrical parts CD47-Bot Extra Discussion 1 16-01-2004 14:24
