Re: pic: Wheel problem.
were u drifting onto the wood floor? and does the wood floor have a lot more friction? idk maybe the sliding sideways is fine on the regolith but when they go onto something of greater friction the wheels cant take it. i wouldnt think that would cause them to fail but its a possibility
o wait is the hub broke? maybe too much sudden torque like changing directions very quickly |
It might be a general stress fracture, considering the wheels (hub and tire) have ZERO give when it comes to bumps, such as driving onto a panel. I sure hope it isn't common, and that you guys get replacement wheels soon.
can you post a picture of a wheel "as assembled"?
are you using a plate sprocket, or one with hubs? if you are using a plate, is there enough clearance between the chain and the wheel material, or is there some rubbing? We have been driving the new wheels for about 2 weeks on a practice chassis (with #35 chain, KOP bearings, fixed axles and aluminum sprockets) and have not seen any issues at all. |
it might be the shock from the regolith to the wood... kinda like skidding out on ice then sliding onto pavement.
Don't use LocTite on you wheels... It dissolves the plastic. Your picture is what our wheels looked like a day after we tapped the wheels for the 10-32 screws and applied LocTite.
Bummer! ![]() |
Well we did not locktite the wheels. It was hard enough to get those screws in there after we tapped the holes. But i do know that there is not a lot of friction on the wood. Its a gym floor. basketball court. whatever you want to call it. Theres no hub, just a sprocket spaced by the spacers provided with the wheels. Theres a ton of clearance using #35 chain. So... i hope it was a bad batch or something... because this competition requires drifting and sliding. Who knows what went wrong...
| Autonomous Two wheel problem??? | fallen751 | Programming | 4 | 11-02-2007 23:07 |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: da wheel | CD47-Bot | Robot Showcase | 11 | 08-02-2004 22:04 |
