Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 17-01-2009, 21:02
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: pic: Wheel problem.
Yeah, a pic of how you mount your wheels to the sprocket would be helpful for advice; however, I'm guessing its how you screwed the sprocket onto the wheel... What I would suggest doing (what has worked for our team this year, and with the past KOP AM wheels) is using a 2" long 8-32 going on the sprocket through the entire wheel, with a nylock on the other end. Tapping may seem like a weight savings, but its a little more work, harder to repair/replace, puts the weight in a smaller area, and may loosen if you don't use LocTite, which can weaken the plastic!
So, I don't know what your team was doing, but I think if you reconsider the wheel mount and buy replacement wheels you should be fine!
Autonomous Two wheel problem??? fallen751 Programming 4 11-02-2007 23:07
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
