Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Unread 18-01-2009, 12:17
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Smile Re: pic: Wheel problem.
Just to clarify what happened last year in elims in Atlanta last year had nothing to do with hub disintegration. As a matter of fact, the hubs withstood the defensive attack from a robot that got under our frame with a side hit placing tremendous lateral load on the wheels, breaking the spokes as well as one of our drive chains. If the mods weren't done as outlined, these lateral loads would have disintegrated the hubs. The loads just got transferred to the next weakest link. In any event, the information was presented to help others solve a potential problem with the wheels as shown in the photo. Use or discard the information as you see fit.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Autonomous Two wheel problem??? fallen751 Programming 4 11-02-2007 23:07
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
