Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
Unread 18-01-2009, 21:52
CraigHickman
Re: pic: Nah, We just have a set for the Alpha bot and the beta Bot
Might be a dumb question, but are you using 2 wheels per module? By the looks of the housing, the width seems to be quite large.
It's actually another method of crab to do that. You can run the drive shaft straight down to the miter gears, which removes the need for either chain or spur gears to drive the wheels. It makes for a less complex swerve module, but at the expense of a hefty amount of (horizontal) space.
I'm guessing that's what they've got going here.
Introducing the FEDS 201 Bot for 2008! Tim Spry Robot Showcase 3 27-02-2008 19:03
pic: Q in arctic - nah just in indy - 1024's stompin ground Qbranch Extra Discussion 13 06-02-2007 17:29
pic: Team 176 bot just before shipping BobC Robot Showcase 2 28-02-2005 23:33
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
pic: Guess the Bot. CD47-Bot Robot Showcase 5 04-03-2004 14:35
