#28
Re: pic: Wheel problem.
The wheel hubs are sized for #8 screws. Did you drill them out before you tapped them for the #10's? If not, you could have stressed the plastic when you used the tapping tool to create your threads. |
| Autonomous Two wheel problem??? | fallen751 | Programming | 4 | 11-02-2007 23:07 |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: da wheel | CD47-Bot | Robot Showcase | 11 | 08-02-2004 22:04 |
