#29
Re: pic: Wheel problem.
This is the link to the AndyMark Cad file, which clearly shows the sprocket mounting holes to be 3/16" (.1895).
http://lib.store.yahoo.net/lib/yhst-...lick-Wheel.pdf The tap size for a 10-32 is about 5/32" (75% thread clearance), clearly smaller than the existing hole in the wheel. It would seen to be far better to open the hole slightly for the #10 bolts to go through, and jamb nut the bolt/sprocket /wheel assembly together. #8 bolts would be too sloppy in the existing holes (maj. diam. of .164"). ![]() |
| Autonomous Two wheel problem??? | fallen751 | Programming | 4 | 11-02-2007 23:07 |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| pic: da wheel | CD47-Bot | Robot Showcase | 11 | 08-02-2004 22:04 |
