Go to Post Did you NOT see the last caption contest???? - Tom Schindler [more]
Unread 19-01-2009, 14:35
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
Re: pic: steering methods
if skid steering is used (2 left wheels in-line and driven 1 speed, 2 right wheels in-line and driven another speed), and the side robot is up against the wall where wheels on one side are on carpet and the wheels on the other are on the slippery field, then will the robot be able to away from the wall?another method would be flywheel steering where the one side is pushed up or down to turn the bot with the forces from the torque produced from trying to tilt the axis. that may not get you away from the wall either though.
i think articulated steering is necessary.
Methods of Scoring Magnechu Rules/Strategy 5 12-01-2009 17:43
Methods of communication???? aviv Chairman's Award 3 18-02-2006 20:10
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
pic: Steering mechanism jskene Robot Showcase 16 17-02-2005 23:20
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
