Go to Post Don't worry about someone stealing your ideas...if they're good ideas, then imitation is the sincerest form of flattery. If they're lousy ideas, we'll let you know, so you can work on finding a better idea. win-win! - MrForbes [more]
Unread 21-01-2009, 07:03
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Smile Re: pic: Wheel problem.
Checked the wheel mounting hole size last night on a wheel, and they are definitely NOT sized with a 10-32 or 10-24 tap hole. An 8-32 clearance hole is about right, but a little more sloppy than I would normally like. If you keep your sprocket and spacers centered on the wheel hub, the 8-32 bolts should work fine, and you will eliminate sprocket runout. Sorry for my previous post, but I even checked with A/M and was assured the CAD drawing was correct a 3/16".
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Autonomous Two wheel problem??? fallen751 Programming 4 11-02-2007 23:07
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
