Go to Post I would like to complain about the game as well. Complain, complain. - Monochron [more]
Unread 21-01-2009, 23:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: pic: 148 Follower Wheel Assembly
Originally Posted by Raul View Post
Humm - how much bigger than the green gear is that omni wheel? The reason I ask is because on the carpet, the wheel may sink in enough to allow the gear to grab some carpet fibers.
Also, is it just pivoting off the robot frame from that empty set of holes, and thus using gravity to keep it in contact with the floor?
It's 1/8" bigger radially. It should be okay, if there are problems during testing I'll tweak things a bit. We plan to spring load it down. Spring tension, TBD. Surgical tubing, of course.
Originally Posted by Joe Ross View Post
We were planning to do the same thing, but with all vex components, including the new encoders. Hadn't gotten to it yet.
The electrical engineers on our team say I have an "encoder mental block" where I refuse to model them into the final design. I had a heck of a time cramming them into Tumbleweed last year. This year we knocked em out almost immediately so they'll keep their mouths shut.
Soo.... will Vexlabs be selling these?
How much would you pay for one? I'm starting my own company KarthikJohn.
We had a similar plan, and were thinking if gravity wasn't sufficient, a rubber band to add a slight amount of tension would be easy enough.
I think with some down-force this should get pretty good grip on the regolith.
Originally Posted by artdutra04 View Post
I'm about 95% sure it's 24 diametric pitch.
Edit: Yup, they're 24 DP.
Yes, 24DP. We just modded the VEX 60t Gear Model to make the coupler piece. Works pretty well.
The side plates are laser cut ABS, 1/8" thick (cut on our small 12x24" laser, not the big one that does the sheet-metal.) The coupler is 3D printed ABS on our Dimension SST. I feel pretty darn spoiled.
Probably could have gone with a smaller package, but we've got plenty of room in the drivetrain to mount it. Like Raul said, if the 60t gear catches some carpet we may change it. I'm not real concerned. *Shrug* This was done quickly and the design group moved onto other things.
-John
pic: Team 148 Engineers Brandon Martus Extra Discussion 9 16-02-2009 23:08
pic: 148 Puncher JVN Extra Discussion 13 12-04-2008 00:04
pic: 148 + 217 = 128 Richard Wallace Extra Discussion 8 04-03-2007 17:42
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
Image Discuss: Team 25 modular gearbox and modified wheel assembly CD47-Bot Robot Showcase 6 10-02-2003 20:02
