Go to Post I can't imagine Wildstang without tiedye... it just wouldn't be right. - Jeff Waegelin [more]
  #41   Spotlight this post!
Unread 22-01-2009, 13:12
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
Re: pic: Ball Harvester
Here's a tidbit we've found:
We've found that while on a slick surface, about half the time the orbit balls run away when they're hit wrong by the harvester fingers ... so having the roller edge @ 9" off the floor with the fingers extending down to 7.5" is our best solution. The harvester roller edge is 8" from the opposite conveyor side though, so the ball is under slight compression while in the conveyor.
Are you guys integrating tubing/belting in between the fingers for the conveyor? If so, have you solved the issue of the belting getting caught on the harvester fingers? That's our next thing to tackle.
We came to some of the same conclusions. We are using 7 inch compression, hope thats not too much. We will show more detail of the harvester soon. We rae going to use polycord between the pneumatic tubing
Faridodin "Fredi" Lajvardi KD7WKD
pic: CD 7 ball harvester BlazinFire47 Extra Discussion 21 14-05-2012 09:56
Knocking off a ball while possesing a ball Joe Ross Rules/Strategy 25 10-03-2008 18:49
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Chief 47 ball harvester 2002 pics ajlapp Robot Showcase 6 11-01-2006 15:34
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
