Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 22-01-2009, 21:07
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: What are we up to? FRC1771
Thanks everyone. I kinda left off the specs so here goes:
-6wd with a dropped center wheel and the center wheel is directly driven off of highly modified tough boxes
-The frame was designed so that everything was aligned by tabs for easy assembly and boat building epoxy was used
-This frame is much stiffer than our custom 1/4" thick aluminum frame last year for an approximately 10lb weight savings.
As for whats going on top, it is eerily similar to what you guys have already posted up with a few differences. Mainly we will be able to shoot downwards at a 40 degree angle without reducing the speed of our shooter. Hopefully everything comes together
O and this is bot #2...the real thing will be even nicer
Mentor 2415
pic: What are we up to this summer... ZZII 527 Extra Discussion 6 19-07-2008 15:29
pic: What are we up to? AdamHeard Extra Discussion 16 08-05-2008 22:50
pic: What are these parts? AdamHeard Extra Discussion 15 18-07-2007 00:40
pic: What?! The Killer Bees are team 47? Tim Baird Extra Discussion 1 15-07-2007 00:33
pic: What are YOU bringing to the competitions??? killerofkiller Extra Discussion 17 01-03-2005 11:51
