Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 23-01-2009, 10:09
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Re: pic: 2013 gnomes robot sneak peek
hmm, just curious... How do you plan to slide the little screw holders into the t slots?
Also, if you were goign to weld it like that, why not just use 1x1x1/8 aluminum square tubing?
pic: Sneak peek at 09 controller Pjohn1959 Extra Discussion 1 20-04-2008 22:23
pic: intelitek's present to you.....a sneak peek at easyC PRO! Jessica Boucher Extra Discussion 22 02-01-2007 14:06
pic: Sneak peek Team 858 Delphi Demons CD47-Bot Robot Showcase 3 02-02-2004 16:43
Sneak Peek Stormhammer Robot Showcase 1 20-01-2004 15:35
vB 3.0 - Sneak Peek Brandon Martus CD Forum Support 13 30-06-2002 23:38
