Go to Post Just remember, a spark of inspiration can produce a lifetime of success. - JoeXIII'007 [more]
Unread 23-01-2009, 11:59
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Re: pic: Pic 2: "caster wheel" crab drive combo
Originally Posted by JHSmentor View Post
did you try direct driving the wheels rather than using the chain? could save you some weight and be a little cleaner setup - not sure if you would have enough clearance for the caster setup though.
Other than that - I love it.
We're doing direct drive on our 6wd, which made me think about why they weren't doing it. I figure that with the direct drive, they'd have to support the end of the shaft to keep from getting any negative cantilever forces on the wheel. Since they aren't doing a standard crab module, they really don't have an easy way to support the end of a direct drive shaft.
With the two little side plates going down to support the chain driven wheel, they instantly have a well supported wheel with no cantilevering.
At least, that's how it seems to me.
-Greg
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: Crab Drive Frame evanisthat! Extra Discussion 15 19-12-2007 20:04
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
