Go to Post Just because you haven't witnessed parts leaving the flywheel yet, doesn't mean it won't happen. - Al Skierkiewicz [more]
Unread 23-01-2009, 14:59
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: pic: Pic 2: "caster wheel" crab drive combo
Originally Posted by Greg Peshek View Post
We're doing direct drive on our 6wd, which made me think about why they weren't doing it. I figure that with the direct drive, they'd have to support the end of the shaft to keep from getting any negative cantilever forces on the wheel. Since they aren't doing a standard crab module, they really don't have an easy way to support the end of a direct drive shaft.
With the two little side plates going down to support the chain driven wheel, they instantly have a well supported wheel with no cantilevering.
At least, that's how it seems to me.
-Greg
Yes, I had the same concern with the cantilever affect but I found a way to mount the wheels very close to the toughbox as a direct drive (through some good luck while using Autodesk). with the low friction surface this year and decent weight balancing, I think this will work out fine. But, supporting the wheel on both sides eliminates that concern so it should be more robust with the only real downside being added weight.
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: Crab Drive Frame evanisthat! Extra Discussion 15 19-12-2007 20:04
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
