pic: Weight Cutting on new CNC
Re: pic: Weight Cutting on new CNC
what is the size and thickness of that tubing?
Have you deburred the cuts in this picture?
The cuts were only partially deburred so they were safe to handle. The team was really excited about getting the robot together and driving last night.
what spindle speed did you have that at. unless yours is like ours (only 500 rpm) then you should either spin it faster or move it slower. saves on time
Did you mill out from all 4 faces?
Sweet!, you must've taken out a few pounds
It dropped from 2.4 to 1.4
speeds and feeds my friends
http://en.wikipedia.org/wiki/Speeds_and_feeds worst comes to worst run it slow(table speed) and at like 1200 rpm on the spindle remember it's cnc so there no race to get it done, stick a green horn in front of it and tell them to hit the estop if things get exciting |
#10
A belt sander or fly cutter could get rid of a majority of those burrs
#12
the face your seeing has not been deburred.
did i go a little fast...yes i did...does it matter to me...nope.. We are having some issues with the mill and CAM software not communicating very well. Have been trying to fix the issue with the company...but until then...its guess and check. |
| EMC linux + CNC mill + CNC Lathe | Leav | Technical Discussion | 8 | 09-11-2008 23:08 |
| Intelitek CNC Motion - Virtual CNC Machines | Kingofl337 | Programming | 0 | 19-03-2008 11:29 |
| pic: 1251 Cutting at Sonny's | David Guzman | Extra Discussion | 9 | 27-01-2008 23:23 |
| pic: Team 75 cutting equipment | Rohith Surampudi | Extra Discussion | 8 | 13-02-2006 19:37 |
| pic: 571's new gearz loose weight | CD47-Bot | Robot Showcase | 24 | 16-04-2004 16:35 |
