Re: Orbit Balls
If you're in Israel, it might be a long flight to the nearest Walmart
Re: Orbit Balls
you got that right..
nothing is easy when located so far away. ![]() |
Re: Orbit Balls
May:
the bands on the inside can be made from lexan plastic, and the padding can be either very thin foam, or just cotton batting (we used cotton - cheaper and easier to work with). Although the original balls use a plastic connector to connect the bands when you fold them, we have used two holes (drilled in the end at a diagonal from each other) so that if you overlap the ring ends you can put a pop-rivet through the holes and attach. There are several good step-by-step construction instructions on Chief Delphi, or feel free to contact Team 1511 at www.penfieldrobotics.com for help with construction tips. Since we're making over 100 of them to host a local competition we've been getting pretty good at it ![]() Cheers, |
Re: Orbit Balls
One of the coaches massed a few of them, and they are 235g.
Re: Orbit Balls
Re: Orbit Balls
No problem, he wrote it on some of them. At first I thought we had bummed some orbit balls from team 2359.
Re: Orbit Balls
Here are two links that might be helpful...
HOW TO: Make Homemade Orbit Balls http://www.chiefdelphi.com/media/papers/2187? and Orbit ball template http://www.chiefdelphi.com/forums/sh...ght=orbit+ball You might be able to make them from these... |
| Throwing Orbit Balls | Skifanatic | Rules/Strategy | 26 | 07-02-2009 07:29 |
| Orbit Balls spotted | Alwaysgo | General Forum | 3 | 09-01-2009 14:55 |
| Diameter of Orbit Balls? | excel2474 | General Forum | 3 | 05-01-2009 12:33 |
