Go to Post It will be really cool if it works, sad if if doesn't. We got our fingers crossed! - falconmaster [more]
Unread 26-01-2009, 16:40
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Re: pic: DOC V: THE RING OF FIRE
Originally Posted by Magnechu View Post
How will you hold balls until your next to a trailer?
we have a mechanism that isn't pictured there.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 26-01-2009, 18:54
Sebastian1646's Avatar
Sebastian1646 Sebastian1646 is offline
AKA: Sebastian phillips
FRC #1646 (precision guessworks)
Sebastian1646 will become famous soon enoughSebastian1646 will become famous soon enough
wow thats really BEASTY!!!
Unread 27-01-2009, 13:46
newyorkjr newyorkjr is offline
FRC #1477
newyorkjr is an unknown quantity at this point
So the balls are pulled out by gravity? Conveyer to get it up there?
In this design, having any kind of launcher at the end of the bot is redundant since the pipes direct it at such a low angle.
Only problem is distance. Even at a height of 5 feet, you may be able to get a ball at max 3 - 5 feet. There is also the penalty of getting hooked onto your opponets trailer. I dont know if that was part of your stratgey but you defintately need to cut the pipes back in order to ensure that you will not get a penalty by accidentally hooking onto a trailer.
*I made spelling mistakes, I know*
Unread 28-01-2009, 18:52
Andrew Nabors
AKA: Andrew Nabors
We have a mechanism at the top helping the balls out.
Unread 29-01-2009, 13:07
FRC #1477
Yeah, I can see that. I'm also assuming that the device to help pull the balls out also pulls the balls up to the top of the robot. But that still means that you don't have that much range. So I'm guessing that your plan is to "corner" an opponet's trailer and dump as many balls as possible into the trailer. That means that whatever encourages the balls to leave ur bot must have the ability to get a lot of them out in a very short period of time. Which also means that whatever system that you are using to get the balls up to the top of the bot must be able to get them up at a very quick pace (cim with 4:1?).
But thats just guesses.
Unread 29-01-2009, 13:32
Andrew Nabors
AKA: Andrew Nabors
There are 3 mechanisms:
1 sucking the balls in
1 pulling the balls up
1 pushing the balls out
pic: FIRST RING matt 1923 Extra Discussion 33 04-03-2008 21:35
pic: Championship Ring KF987 Extra Discussion 8 10-07-2007 17:41
pic: Logo on Ring Donut Chit-Chat 14 30-12-2006 20:33
The Ring Collin Fultz Chit-Chat 26 07-02-2003 16:18
Presenting the FIRST forum ring archiver 2001 0 24-06-2002 00:42
