Go to Post Advances in STEM are meant to benefit everyone, so even the most basic-level of understanding deserves to be validated and encouraged. - moamomen [more]
Unread 25-01-2009, 02:45
Re: pic: 816 as of 1-24-09
Originally Posted by jason701802 View Post
I've never seen belting like that, what is it?
Its just wheel tread or conveyor belting. Cut into strips.
Unread 25-01-2009, 02:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It's a segmented V-belt. It's made from some sort of fabric laminate, and composed of individual links. You twist the tab 90° and insert it into the slot on the next link; then untwist. They lock together under tension.
I believe that Small Parts sells it...this ought to be it. (188 used it for a hybrid wheel-tread thing on the 1999 drivetrain.)
Unread 25-01-2009, 03:00
Really now? Doesn't look like anything more than wheel tread...
Huh. Never seen that before then...
Unread 25-01-2009, 13:00
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by Michael Corsetto View Post
Is the kinda "gut" area between the intake roller and conveyor belt system used for storage, or is it blocked off with lexan so the balls can't bunch up? How many balls can the system hold? How well does that front roller grab running at 600rpm? What sort of compression do you put on the balls for the front roller and conveyor system? Sorry about all the questions, looks like a pretty slick design, post video soon please
Most of the front open area is used as a hopper of sorts some of it will be used for electronics mounting. If you look closely you can see 2 pieces of angle just kinda sitting there and thats where our electronics shelf mounts to. Theoretical capacity is between 15-20 balls depending on how they all settle in the system. The front roller grabs very well and can handle 2 balls at a time and both the conveyor System and front roller compress the ball about 1/2" give or take a bit depending on what you say a ball's diameter is (I say it's 9").
Originally Posted by dtengineering View Post
I don't know if you've already got something planned, but have you thought about protecting the intake roller?
On impacting the corner of another robot, the contact may not be bumper-to-bumper, but rather the edge of the other robot (usually reinforced or supported) to the centre of your roller. Perhaps the roller is designed to take this kind of hit, but it would be a shame to see a nice looking robot like that out of commission due to a weak point.
Assuming the roller IS designed for a full-on impact, if the relative velocity of the two robots is at an angle, can the roller mounts take a sideways impact force?
Jason
In theory the front roller should never be hit. It's about 8.5 inches off the ground at it's lowest point which is out of the bumper zone. If it did hit the structure of another robot I hope it'll break and then we just have to replace a piece of pvc. On Monday I'll look into making a guard for it so that it would be metal to robot contact before robot to roller.
Thats the exact belt I think. We've had it for years and I believe we got it from the HVAC Teacher at my school because they use it for belting on compressors.
-Dustin Benedict
Unread 25-01-2009, 13:33
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Nahhhh Kramers dad gave it to us. I remember he brought it in and I was like WTH is that?
Unread 25-01-2009, 18:36
Close up pic please.
Unread 25-01-2009, 21:08
thefro526's Avatar
Mentor for Hire.
Of the belting? I'll take one tomorrow.
-Dustin Benedict
Unread 26-01-2009, 00:55
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
The bot looks really killer. Out team is doing something similar.
I really like the design hope you do well
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 26-01-2009, 22:03
thefro526's Avatar
Mentor for Hire.
As It sits tonight....
Belting.....
-Dustin Benedict
Unread 27-01-2009, 09:28
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
It looks like this V-Belt belting from McMaster: 6173K41. Not sure if that's the right width, or if that's the right stuff, but it looked familiar when I saw that picture and I remembered seeing it when looking at belts.
It may or may not be it for people looking for the same stuff.
-Greg P.
Unread 27-01-2009, 12:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Dan & Dustin, where are you guys competing this year?
Edit: Never mind, TBA says Philly again & NJ? Too bad you won't be in NYC with us.
Looks like another awesome bot by 816 this year after last year's cool bot as well!
Unread 27-01-2009, 12:50
pgaston pgaston is offline
FRC #2103
pgaston is an unknown quantity at this point
Another request - that belting looks neat - what is it? where'd you get it?
Unread 27-01-2009, 17:54
thefro526's Avatar
Mentor for Hire.
We'll Be competing in Jersey, Philly and The Championship. It sucks that we won't get another opportunity to kick some butt with you guys. I might have to make the trip up to NYC to see you guys in action though.
We got it donated. There's a few links to it in the above posts.
In Robot News!
During School today I rigged the motors together to see how everything's going to work and it looks good. Our Capacity should exceed 20 and we can score 3 at at time with about a 90% success rate. It takes about 3-4 Seconds to offload 10 balls.
Might Have Video Tomorrow or Thursday But I can't promise anything until Friday-Saturday.
-Dustin Benedict
Unread 27-01-2009, 20:44
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Woa how many belts are there?
Unread 27-01-2009, 23:10
thefro526's Avatar
Mentor for Hire.
Only 7 Actual Belts. But we have a bunch of little belt wrapped around the rollers to make them grippier.
-Dustin Benedict
816 in the News!!!!!!!!!!! thefro526 General Forum 4 22-02-2008 18:15
