Go to Post what fun is it if you haven't ripped out all your hair and beaten your now bald head against the wall for extended periods of time.... - pickle [more]
Unread 27-01-2009, 10:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: pic: Is this corner considered protected?
Originally Posted by dlavery View Post
The question in that Q&A post never asked if the configuration on their robot was illegal or not. So of course they did not get a determination of the legality of the configuration.
Had they asked about that specific robot, they would have been referred to team update 6 and still not get the answer they wanted.
Unread 27-01-2009, 20:33
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Talking Re: pic: Is this corner considered protected?
technically you only need to cover 3 sides lol, im jk but really i would consider this well over the range of legal. The trailer aint bumpin so it seems perfectly fine lol
Unread 27-01-2009, 20:45
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
But the rear corner is not protected on both sides
Unread 27-01-2009, 21:00
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
As a Lead Inspector in many Michigan Events I can see a headache in the making. I hope many of the bumper issues stated here are not typical.... bottom line is.... the rules rule!
Mike Martus
Unread 28-01-2009, 00:06
Scott Hill Scott Hill is offline
FRC #1625 (Winnovation)
Scott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to behold
the drawing shows a ROBOT BUMPER PERIMETER with BUMPERS (blue) and corner fillers (red) which I think reasonably represents the ROBOT and CORNER in question.
The BUMPER PERIMETER is a polygon. The polygon has 6 corners; A,B,C,D,E,F. 2 of the corners, D,E, have right angles. 4 of the corners, A,B,C,F, have obtuse oblique angles. The polygon has 6 sides; AB,BC,CD,DE,EF,FA.
The corner in question with respect to this thread is corner A. There are 2 sides "of corner A", side AB and side FA.
Each side of the corner, side AB and side FA, is protected by BUMPERS. Each sides protection clearly meets the intent of <R08> ..."If implemented as intended, a ROBOT that is driven into a vertical wall in any normal PLAYING CONFIGURATION will always have the BUMPER be the first thing to contact the wall."... . Side AB has no BUMPERS on it yet the BUMPER configuration clearly meets the intent of the rule, which is clearly stated.
EricH, I enjoy reading your may posts in these fora. I think you do a lot to contribute positively with your comments. However I must take issue with your position on this question. What I believe are the relative sentences from your referenced sources follow, with my comments appended:
Reference #1: "Both sides of the corner must be protected." Comment: they are, see above.
Reference #2: "Both sides of the corner must be protected by BUMPER segments." Comment: they are, see above. "Rule <R08-i> requires BUMPER protection on every corner of the BUMPER PERIMETER." There is obviously BUMPER protection on every corner of the BUMPER PERIMETER, see above drawing.
Reference #3: This reference is not on point because the answer is given with respect to a rectangular ROBOT BUMPER PERIMETER, not the BUMPER PERIMETER in question.
Reference #4: "The interpretation that "both sides of an exterior corner must be protected with segments of bumpers, and the bumper segments must be a minimum of 6 inches" is correct." Comment: both sides of the corner are protected, see above, and the bumper segments in the example can be easily made to meet the 6" minimum dimension requirement.
Mike8519: You state ..."those corners must be protected by 6" of bumper on each side"..... I think if you read carefully the requirements typically state ..."both sides of the corner must be protected"... not, corners must be protected on each side. They do not mean the same thing.
Thanks to all for contributing to the discussion,
Scott
Unread 28-01-2009, 00:20
EricH EricH is offline
Originally Posted by Scott Hill View Post
[edited for brevity]
Please note the plural form. The GDC has been quite clear on this. There is bumper protection, yes. It is protected by a bumper segment. I'm nit-picking here, but it seems that this would be illegal.
Again, plural form is used.
While the words don't mean the same thing, the first is a subcase of the second. The first is also what the GDC seems to be saying.
I know how we can settle this once and for all. Submit the picture to Q&A. Ask: "Are corners A and B adequately protected under <R08>? If not, why not?" If they don't refer you back to the rule, they will hopefully give a straight answer.
The other option is that they say, "we cannot comment on specific robot designs", in which case I would advise having a more conservative route available at the event or just plain installed on the robot.
Unread 28-01-2009, 00:35
EricH,
Thanks for your comments.
Question: If the plural is required as you say and "protected by a bumper segment" would not be legal, as you suggest, is a robot side legally protected if it is covered completely by only one bumper segment?
I think it would be.
I also don't see how you can consider the first of the two statements as you list them as a subcase of the second. I have never seen the GDC say the first, and I have quite often seen them specifically say the second.
Scott
Unread 28-01-2009, 00:42
EricH,
We aren't considering sides, are we? We are considering corners, which are a junction of two sides.
Scott
On this, I have reviewed. If the corners must be protected on by six inches of bumpers on both sides, then by definition, both sides are protected. So the second is a subcase of the first, but may also stand alone. I stand corrected.
However, I now have some more things to consider. Several teams have recently asked, "will bending 1 6+" bumper segment around a corner be legal if we don't have backing in the corner and we have less than 6" on one side?" or something to that effect. The GDC has answered no to all cases like this. But if you had a 13" piece of bumper, broken into 2 6" segments and a filled, I'm pretty sure that would be legal. Just some food for thought.
Unread 28-01-2009, 00:50
EricH,
I believe the statements you included were referencing the sides of the corner.
Thanks,
Scott
Unread 28-01-2009, 01:25
EricH,
Thanks,
Scott
In which post?
The debate here (to remind ourselves and inform anyone just joining us) is over one simple question: Do both sides of a given corner have to be protected by bumper segments of 6" or more?
I am going to state the full reason for my interpretation. This will take a while, so bear with me.
My response will follow the reverse chronological order in Q&A.
http://forums.usfirst.org/showthread.php?t=11635
3 rules are cited. One is hard parts in a corner, one is the backing. Those aren't relevant here. But the reference to <R08-A> is interesting. Rounding a corner to protect both sides results in 2 segments. Neither is long enough in this case.
The next one regards the design under consideration. http://forums.usfirst.org/showthread.php?t=11600
However, it only covers defining an exterior corner.
http://forums.usfirst.org/showthread.php?t=11609 Clarification that no, you can't wrap a bumper and have it be one segment. From henceforward, I will ignore those Q&As that cover this topic, unless something else is answered.
http://forums.usfirst.org/showthread.php?t=11454
They are considering a similar setup. Note that the GDC says, "We can't rule on specific designs. We leave that to the event inspectors."
http://forums.usfirst.org/showthread.php?t=11471
This one is annoying. It references Bill's Blog and sets off a chain of research. Ah-hah! Bill's Blog has something: http://frcdirector.blogspot.com/2009...r-musings.html
Unfortunately, this is an unofficial channel. Nonetheless, point 3 is important. Remember, Bill is on the GDC. This is by no means official, however. I will deal with the rest of the research later, if necessary.
OK, I lie. This one is referenced to ask the previous question. http://forums.usfirst.org/showthread.php?t=11170
Note: the relevant question, #1 in the second post, is not directly answered. However, the logic is confirmed.
http://forums.usfirst.org/showthread.php?t=11218 is perhaps the most direct. See the GDC's first paragraph. This is one disagreed with earlier. I will simply say, note the plural.
http://forums.usfirst.org/showthread.php?t=11159 is also referenced by the one that references Bill's Blog, though through a chain. #2 is the relevant point here. It's another "answer with a not-quite answer".
http://forums.usfirst.org/showthread.php?t=11056 Here's one for you. They say that at least part of the fourth side of a 4-sided robot must be covered by bumpers. If that holds with an extra 2 sides...
http://forums.usfirst.org/showthread.php?t=10933 and http://forums.usfirst.org/showthread.php?t=11070 address the issue directly and are vaguely answered, at least as concerns this discussion.
Those are all that I could find relating to this topic. Taking those together, I conclude that the corners A and B must have a 6" segment of bumper on both sides, which is impossible due to the location of the trailer hitch. Therefore, a design change must be made. If there are questions as to why I interpret a response the way I do, go ahead and ask; I could be wrong.
Edit: Dave responded in the thread with just the overhead view. His response (barring an official overturning from the GDC via Q&A) is that the configuration won't pass inspection.
Unread 28-01-2009, 02:10
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It looks like you're suggesting that any bumper design that satisfies the condition in the intent statement offers the required protection. That's not unreasonable, but I don't think that's the way that the GDC understands it.
As a test case for your theory, consider a robot similar to the one you posted above. Move the trailer hitch out of the way (put it in the gap on DE). Delete the section AB. Extend the segments FA and BC to their intersection, and call it G (but leave the bumpers as-is). Delete points A and B, leaving us with rigid segments GC and FG. Now, if we perform those operations on the picture above, we end up with a big sharp corner (at G) that clearly extends beyond the bumpers. This contravenes the condition in the intent statement, and is not protected by segments. But what if we made the angle at G something large, like 170°? There is still a corner (a discontinuity in the radius of curvature), but now the thickness of the existing bumpers allows it to pass the intent statement's condition (the corner doesn't stick out past the outermost edges of the bumpers anymore).
Is it your contention that even though the 170° corner at G is not abutted by any bumper segments, all necessary conditions are met (because the bumper hits first), and it would therefore be legal? If that's the case, then the amount of protrusion (inward or outward) past the edge of the bumpers is the most critical factor in determining protection (under your theory).
Apparently, the GDC considers the condition in the intent statement and the corner protection requirement to be separate, necessary conditions. Furthermore, it looks like they understand corner protection to mean a design with a legal bumper segment on each side of the corner.
Assuming that the function of the Q&A is to guide the interpretation of rules, but not to impose additional constraints*—that being the function of the rules and updates—the GDC's responses regarding corners have been mutually consistent and legal under the rules—so following them precisely ought to be acceptable at any event. (That's your best course of action.)
There might be some room for your interpretation, however: the GDC is describing a legal way to meet an existing requirement (protection of corners per <R08>, part I), but there's nothing in a rule or update that says that this is the only possible way to protect a robot's corners—in fact, to say that there is only one legal mode of protection (without some sort of explicit definition in the rules) is a bit of a stretch of the principle that the Q&A shouldn't be defining new constraints. (Yet, I think that that's implied here.) So as I understand it, you're relying on the fact that the next best thing to a direct definition of protection is the intent statement, and that because your proposed design passes that test, your corners are protected.
Like I said, it's not unreasonable...but you're taking a big risk that the inspectors at any given event will be open to considering that logic, and will arrive at the same conclusion as you, and that FIRST won't clarify things once and for all in an update (ruling against you).
*FIRST has not stated this directly for a couple of years, but that was formerly the rule of precedence. Maybe they made the statements in the 2009 Q&A binding, but neglected to tell anybody....
Unread 28-01-2009, 00:32
waialua359's Avatar
waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
I agree with this one. There will be many headaches for inspectors and some very unhappy campers on both sides.
The most simplest solution, while it may not allow teams to be as creative as they wanted to be, is to have a frame, that is unquestionably, legal.
From past experience the last several years, I dont want those headaches again as much as possible.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 28-01-2009, 09:53
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I'm with you on this one Glenn!
I think that the GDC has created rules this time, when all taken together, has the intention of driving design; rather than teams coming up with any and all designs and trying to fit/apply the rules to the design. With the stated bumper constraints - bumper segment size, perimeter coverage, trailer-bumper interaction, etc... there will a limited number of designs that meet those requirements!
836 is going conservative to mitigate risks of an un-approvable design. Long configuration - Front opening of 16" (6" of bumper segments on either side), appropriate opening for the trailer hitch and leaving it at that.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Is this considered a hurdle? chaineezee Rules/Strategy 10 07-01-2008 19:12
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
useing Copyright protected music. [527]phil Website Design/Showcase 15 22-10-2006 20:26
pic: Is this currently legal or considered exotic? CD47-Bot Robot Showcase 10 13-05-2003 01:09
Are Grommets considered fasteners? kmcclary Off-Season Events 1 04-11-2001 17:26
