Thread Tools |
Rating:
Display Modes |
Re: pic: DOC V: THE RING OF FIRE
So the balls are pulled out by gravity? Conveyer to get it up there?
In this design, having any kind of launcher at the end of the bot is redundant since the pipes direct it at such a low angle. Only problem is distance. Even at a height of 5 feet, you may be able to get a ball at max 3 - 5 feet. There is also the penalty of getting hooked onto your opponets trailer. I dont know if that was part of your stratgey but you defintately need to cut the pipes back in order to ensure that you will not get a penalty by accidentally hooking onto a trailer. *I made spelling mistakes, I know* |
Yeah, I can see that. I'm also assuming that the device to help pull the balls out also pulls the balls up to the top of the robot. But that still means that you don't have that much range. So I'm guessing that your plan is to "corner" an opponet's trailer and dump as many balls as possible into the trailer. That means that whatever encourages the balls to leave ur bot must have the ability to get a lot of them out in a very short period of time. Which also means that whatever system that you are using to get the balls up to the top of the bot must be able to get them up at a very quick pace (cim with 4:1?).
But thats just guesses. |
1 sucking the balls in 1 pulling the balls up 1 pushing the balls out |
| pic: FIRST RING | matt 1923 | Extra Discussion | 33 | 04-03-2008 21:35 |
| pic: Championship Ring | KF987 | Extra Discussion | 8 | 10-07-2007 17:41 |
| pic: Logo on Ring | Donut | Chit-Chat | 14 | 30-12-2006 20:33 |
| The Ring | Collin Fultz | Chit-Chat | 26 | 07-02-2003 16:18 |
| Presenting the FIRST forum ring | archiver | 2001 | 0 | 24-06-2002 00:42 |
