Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Unread 24-01-2009, 15:35
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
pic: Weight Cutting on new CNC
Unread 24-01-2009, 15:36
NickE's Avatar
NickE NickE is offline
_
Re: pic: Weight Cutting on new CNC
what is the size and thickness of that tubing?
Unread 24-01-2009, 15:52
CraigHickman
Have you deburred the cuts in this picture?
Unread 24-01-2009, 16:19
Ian G Ian G is offline
BUILD SUCCEEDED
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
The cuts were only partially deburred so they were safe to handle. The team was really excited about getting the robot together and driving last night.
Unread 24-01-2009, 20:41
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
what spindle speed did you have that at. unless yours is like ours (only 500 rpm) then you should either spin it faster or move it slower. saves on time
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 24-01-2009, 20:46
Did you mill out from all 4 faces?
Unread 27-01-2009, 21:07
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Sweet!, you must've taken out a few pounds
Unread 27-01-2009, 21:24
RMS11's Avatar
Safety!!!!
AKA: Rick
It dropped from 2.4 to 1.4
2009 Palmetto Regional Champs
Unread 27-01-2009, 21:45
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
speeds and feeds my friends
http://en.wikipedia.org/wiki/Speeds_and_feeds
worst comes to worst
run it slow(table speed) and at like 1200 rpm on the spindle
remember it's cnc so there no race to get it done, stick a green horn in front of it and tell them to hit the estop if things get exciting
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 27-01-2009, 22:27
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
If you want we have a speed and feed calculator on our site, posted here. Just scroll down a bit. Also on a CNC you have to go fast, why? Cause itz season, time is money. LOL. Need any help on the CNC let me know, our whole bot is CNC'd (New Word, invented it).
R.C.
MadTown Robotics Team 1323
Unread 27-01-2009, 22:32
Hal9000's Avatar
Hal9000 Hal9000 is offline
Machining Addict
FRC #1983 (Skunkworks)
Hal9000 is an unknown quantity at this point
A belt sander or fly cutter could get rid of a majority of those burrs
Unread 29-01-2009, 22:51
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
the face your seeing has not been deburred.
did i go a little fast...yes i did...does it matter to me...nope..
We are having some issues with the mill and CAM software not communicating very well. Have been trying to fix the issue with the company...but until then...its guess and check.
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
pic: 1251 Cutting at Sonny's David Guzman Extra Discussion 9 27-01-2008 23:23
pic: Team 75 cutting equipment Rohith Surampudi Extra Discussion 8 13-02-2006 19:37
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
