Re: pic: Skunkswerve Module Cross Section
There is a bearing on each side that is press fit. We some left material in the bottom of the hole for the bearing that keeps them from being pressed through. We drilled and tapped the shafts so that we can secure them in the opposite direction with a washer and a bolt. I'm uploading an Iso view right now.
| pic: Skunkswerve....team 1983 | Bob Steele | Extra Discussion | 22 | 30-01-2009 22:09 |
| pic: Rage 173 cross section of robot in SolidWorks | TriggsJr | Extra Discussion | 20 | 05-05-2005 10:58 |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 13 | 27-01-2005 09:49 |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 0 | 25-01-2005 19:17 |
| pic: 217 Gen 2 Crab Module Section view | CD47-Bot | Robot Showcase | 2 | 28-04-2003 18:26 |
