Go to Post Success in this game comes from a wealth of ideas and good engineering, not deep pockets. - Karthik [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 27-01-2009, 23:17
Re: pic: Robot Bumpers
Well, we might as well have at it again.
I'll start by saying I don't believe this is legal, because corners A and B are not protected on both sides of the corner. I think it is made very clear by the GDC in their response in this Q/A forum post http://forums.usfirst.org/showthread.php?t=10933
In the above picture, I see two corners, A and B, each with one side that does not satisfy the "Both sides of the corner must be protected by BUMPER segments" ruling.
Unread 27-01-2009, 23:23
CraigHickman
To play devil's advocate, the rules (numbers of which I forget) about trailer hitch mounting forbid bumpers in the pivot area. Which rules trumps which?
Unread 27-01-2009, 23:26
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
I think they want both followed. It is to my understanding that you must have bumpers on your back segment (to cover the corners), and those bumpers must not be in the pivot area.
I think that means that you need room on the back for 6" on each side of the pivot area.
Please, correct me if I'm wrong.
-Rizner
Unread 27-01-2009, 23:29
CraigHickman
-Rizner
Again playing devil's advocate (my opinion here is irrelevant), This design follows the intent of all bumper rules. It is well protected from all hits, while still allowing mobility of the trailer. If the bumper rule intent isn't to keep robots protected, then what IS it for? I mean honestly, the rules on bumpers this year are ridiculous to make me reconsider doing next year, as I know they can only follow the same path they've been following the recent years.
Unread 27-01-2009, 23:30
Aren_Hill's Avatar
Build Nifty Things
this pic was posted to explain in the current thread running of "is this corner considered protected" discussion goes there
A guy who likes robots.
Unread 27-01-2009, 23:39
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I call this configuration LEGAL within the rules set forth in the competition manual. It clearly meets the intent and follows all published rules.
Corners A and B do not have to be protected on both sides of the corners because a Q/A response is not a rule.
BTW, I love this topic. We could debate this for years and you could make a good argument either way.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 27-01-2009, 23:46
MrForbes MrForbes is offline
Yeah, it could go on forever...
I think the Q&A response gives the GDC's meaning of "protected" as having BUMPERS on both sides of each corner.
I sure hope they get that into the rules, if that's their intent.
Unread 28-01-2009, 00:01
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
The original intent of this design was to allow the robot to turn tight on the trailer.
This is all in vein. The trailer that everybody built has a ¾ pipe that the hitch assembly allows the trailer tung to move up to 90 degrees. The competition trailer is different and has a 1 inch x 1 inch square pipe with a short pin that is inserted and secured. If you turn the trailer more than 30 degrees the square pipe of the trailer hits the trailer hitch of the robot which is a violation. A turn of 35 degrees gets you to a contact point of a normal square cornered robot. There is no advantage to gain the 5 degrees.
Although I like this year’s game they have tied up the design rules so tight that everybody’s robot is going to be very similar. They are chocking our creative design ideas with every turn. I miss the day’s when you could make it open up as big as you want and did not have to worry about bumpers.
Unread 28-01-2009, 07:48
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Unhappy Re: pic: Robot Bumpers
I must agree, It sounds to me as if they want eveyone to just use the rectangular kit bot chassis, a drawing could be posted showing the only legal bumper configuration, and then we could all just slap some team numbers on and go. I am NOT a fan of bumpers.
Mike d
See Ya
Unread 28-01-2009, 08:11
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
Mike d
Agree totally. The rules this year legislated out a LOT of room for innovation. But FIRST is made up of smart folks; I think (and hope) that next season a little bit more leeway will be given back to us.
Unread 28-01-2009, 20:10
RobotDevil1985's Avatar
RobotDevil1985 RobotDevil1985 is offline
FRC #0533 (PsiCotics)
RobotDevil1985 is an unknown quantity at this point
Every year people will complain that the rules are too strict and that they are limiting the designs. FIRST is meant to make you think about ways to work within extreme constraints, 6 weeks, impossible rules, and really strange games.
Just have fun with it, and don't worry about whether or not you win.
Unread 28-01-2009, 21:09
President, VEX Robotics, Inc.
Scott (and everyone else on 1625),
You are smart people. I have met and talked to many of you, but in my eyes you are making fool's of yourselves. I know you and I have a hard time believing you are actually confused. I know that you try to build really competitive robots and many of us understand the huge advantage the configuration you show above gives a team. The rest of us who have figured that out (148, 254, 1114, to name a few) are not doing it because it is painfully obvious to be illegal based on the rules and Q & A.
At some point, you have to realize that your interpretation is wrong and your implementation is illegal whether you agree with it or not. I still think it is strange that a bumper that measures 9" long is really only 6" but you have to move on. I know the inspectors at Midwest and I will bet you a Mountain Dew they will not let this robot compete as shown above.
Unread 28-01-2009, 21:40
Aren_Hill's Avatar
Build Nifty Things
Paul that picture does not represent our robot fyi.
And we would still be fine if they come out with an update 100% clarifying bumpers must be on both sides of each corner (not just protecting, being there)
It would've been the simplest thing to add to the manual when it was written, and why they didn't I don know. We could've avoided all of this.
and here's the chief inspector himself saying clarifications should be made....
http://www.chiefdelphi.com/forums/sh...8&postcount=29
http://www.chiefdelphi.com/forums/sh...1&postcount=30
Unread 28-01-2009, 21:45
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I'll buy you a mountain dew if you're thirsty. We weren't confused, just thought that this was the correct interpretation of the rules and that it should be debated/defended to the fullest extent.
Unread 31-01-2009, 15:26
winkelman2007's Avatar
winkelman2007 winkelman2007 is offline
another year another robot...
AKA: Tiffany
FRC #0256 (The Rams)
winkelman2007 is an unknown quantity at this point
Send a message via AIM to winkelman2007
Smile Re: pic: Robot Bumpers
does anyone know how far off the ground the bumpers should be? The team im mentoring can't figure it out.
pic: PD-1345's 2008 robot without bumpers Arefin Bari Robot Showcase 2 23-02-2008 23:44
pic: Finished 1024 2008 Robot (without black bumpers to show detail) Qbranch Extra Discussion 5 19-02-2008 20:51
pic: Purple Bumpers - 418 leeweek Extra Discussion 5 05-04-2007 00:12
pic: RC 1736 bumpers bam_415 Extra Discussion 5 27-02-2007 20:12
Robot bumpers EricLeifermann Technical Discussion 15 12-01-2007 02:18
